Slip and Vdc light 2008 g37s
Old May 6, 2018 | 08:00 PM
Fully_peppered's Avatar
Fully_peppered
Hello everyone new to the forum and also to the g community today I left a light and got it on between 2nd and 3rd and the two lights came on same time And stayed in until I turned the car off then back on , is this a serious issue or a easy fix to a small problem??
Old May 6, 2018 | 08:04 PM
Fully_peppered
** also car is stock no mods and the conditions were semi wet or slick I would say and I just looked at fluids and noticed the brake fluid was a little under min , what is the correct or best fluid for the car and if I top it off is there any bleeding or other service I should do along with the top off
Old May 6, 2018 | 08:25 PM
slartibartfast's Avatar
slartibartfast
Welcome! I moved your post the appropriate forum.
Brake fluid spec is in your owner's manual. Just top off the reservoir. If your existing fluid isn't clear, you should flush the system.
Old May 6, 2018 | 08:52 PM
Also if your fluid is to the minimum fill line or lower, be sure to check your pad thickness, may be worn close to the wear indicators.
Old May 7, 2018 | 08:23 AM
Fully_peppered
Awesome thank you very much I’ll look into all of this today and get moving on any issues
yardie_g37_6mt
Apr 12, 2018 03:57 PM
iTzCloud
Intake and Exhaust
Apr 7, 2018 04:59 PM
yardie_g37_6mt
Mar 24, 2018 10:06 PM
Alex458116
General Tech Questions
Mar 24, 2018 03:28 PM
Crusher103
Feb 10, 2018 08:19 PM
