Help Coil Over Install - Difficult?
Old May 2, 2018 | 11:34 AM
Lego_Maniac's Avatar
Lego_Maniac
Originally Posted by Hashim
+ 1 on this. Take the tension off the bolt and it'll pop right off. One tip to do this is to disconnect your swaybar endlink from the swaybar on the side you're working on ...makes it a million times easier to move the LCA
I meant something different....put box end on bolt, put jack under open end of the wrench. Jack.
Old May 2, 2018 | 11:40 AM
Baadnewsburr's Avatar
Baadnewsburr
lol oh my bad, I thought you meant jack under the LCA to take the tension off and use a wrench to keep the bolt from spinning...I just did it this way this past weekend changing my pass side axle (I'm AWD)..always more than one way to skin a cat
misc
Intake and Exhaust
22
Jan 29, 2016 10:26 PM
Emon Crew
Feb 17, 2010 09:54 PM
dmkozak
Aug 2, 2007 03:39 AM
