Akebono bbk fitment
Old Mar 1, 2018 | 12:38 PM
VQCrew's Avatar
VQCrew
Akebono bbk fitment
Sorry if this has been asked a million times, but will 19x9.5 +20 wheels fit akebono brakes?
Old Mar 1, 2018 | 12:45 PM
RMB5190's Avatar
RMB5190
Send a PM to admin/staff: blnewt.
He's the forum guru for all that is Circular and wrapped in rubber.
Old Mar 1, 2018 | 01:08 PM
bPChaos's Avatar
bPChaos
Offset has less to do with clearance than the design of the wheel/spokes. Your best bet is to print the brake template (stickied here: https://www.myg37.com/forums/brakes-...templates.html) and try it for yourself, or send it to whichever vendor you're planning to buy from. I had +38 wheels that cleared and +27 wheels that didn't.
Old Mar 1, 2018 | 02:58 PM
Do you have the model for the wheel? Might have been used around here before and can maybe confirm that way too
Old Mar 1, 2018 | 05:27 PM
VQCrew's Avatar
VQCrew
They are rohana rc10s.
Old Mar 1, 2018 | 11:02 PM
The 20" Rohanas clear, not 100% sure w/ the 19s tough. Might contact getyourwheels.com and see what they say.
Old Mar 26, 2018 | 07:30 PM
BBR318's Avatar
BBR318
Is this the appropriate way to use the templates? Seems like won’t clear my wheels. So close though :’(
Old Mar 26, 2018 | 10:24 PM
That is the correct template placement, as long as the template is printed to scale
There is a little wiggle room in the template but looks like you might need a real thin spacer, like a 3mm, this should still allow you to use your OEM wheel studs.
Old Mar 26, 2018 | 11:32 PM
BBR318's Avatar
BBR318
i shot you a PM not realizing you replied here. thank you for the tips!!! hopefully a 2.5mm-5mm space will work.
ToXIc
Jun 13, 2017 01:25 PM
Bennyjoel
Dec 28, 2016 10:25 PM
rizzagt22
Brakes
Aug 23, 2009 06:27 PM
