G37 Coilovers and camber kit?? HELP!!!
Old Jan 31, 2018 | 09:16 AM
Bvongph's Avatar
Bvongph
Hey guys I need help with my coilovers. I知 new to getting coilovers for my car and I was wondering will I need a camber kit with bc coilovers?? Sorry I知 kind of a newbie also the car is a 2012 G37 Sedan sport.
Old Jan 31, 2018 | 09:59 AM
Surfnazi's Avatar
Surfnazi
Yes you will and cheaper to put in at same time since you're already in there
Old Jan 31, 2018 | 10:02 AM
Bvongph's Avatar
Bvongph
Should I get the front and rear? I was planning to get the rears only🤷*♀️Also should I need a toe kit also?
Old Jan 31, 2018 | 11:00 AM
I would get the front & rear sets, depends how low you plan to drop though. The rear kit should come w/ the toe bolts, make sure they do as you will need them too.
Many only get the rear set, but expect accelerated wear in front if you drop more than 1.25" without a front kit.
Old Jan 31, 2018 | 11:58 AM
Bvongph's Avatar
Bvongph
I’m planing on dropping 2 inch in the rear and around 1 inch front
Old Jan 31, 2018 | 11:59 AM
Bvongph's Avatar
Bvongph
im planning on dropping it 2 inches rear and 1 inch front
Old Jan 31, 2018 | 12:18 PM
I'd keep the rear either the same as the front or slightly higher, G's that are lower in the back look like you're hauling bags of cement in the trunk.
That said, if you want to keep your front alignment closer to spec, a drop of 1.25 to 1.5" all around would be a reasonable range. This would also be much easier to get around vs. a drop lower than that.
Old Jan 31, 2018 | 12:24 PM
Bvongph's Avatar
Bvongph
If I do that I would just need a rear cambe kit correct? You think that kind of drop get rid of all the gaps? ALso your right I知 just looking to look low but easier to get thru town without any hassle
Old Jan 31, 2018 | 12:35 PM
Surfnazi's Avatar
Surfnazi
Do both save yourself the headaches later
Old Jan 31, 2018 | 03:04 PM
hockeyzbh's Avatar
hockeyzbh
I have bc br coils without a camber kit. Is the only benefit of getting the camber that the tires will wear evenly?
Old Jan 31, 2018 | 05:27 PM
slartibartfast's Avatar
slartibartfast
Not just evenly, but the same, too.
Old Feb 1, 2018 | 01:07 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Your #1 Infiniti Vendor!
Get some BC coils with some SPC camber kits.
Contact us for pricing!
-Josh
Nsodano
Dec 24, 2015 07:04 PM
kokoszka
Oct 16, 2014 08:55 AM
Bktin
Apr 3, 2013 11:26 PM
stickboy
Mar 14, 2011 07:31 AM
joo030879
Jun 24, 2010 11:23 AM
