Rusty brake calipers and rotor tophats
Old Jan 22, 2018 | 03:02 PM
Litebody's Avatar
Litebody
So like the title says, I've got me some rusty calipers and rotor tophats. If I used rust converter on them (all I can find is tinted black in rattle can), can I then paint with heat resistant paint? In other words, is the rust converter high temp resistant?
Old Jan 22, 2018 | 03:17 PM
slartibartfast's Avatar
slartibartfast
The rust converter causes a chemical reaction that changes Fe2O3 (red rust) into Fe3O4 (black rust). Don't think your brakes can get hot enough to reverse the reaction.
I see Corroseal adds a latex primer. You might be able to char that, but the black rust will stay black.
Old Jan 22, 2018 | 03:47 PM
Litebody's Avatar
Litebody
Thanks, but wasn't asking if it would return to rust. I was wondering how good a substrate or primer would it privide? Does it burn or peel off?
Old Jan 30, 2018 | 01:13 PM
Surfnazi's Avatar
Surfnazi
If you don't have sport brakes you can wire brush the surface rust off and use high temp enamel engine paint. Rust won't come back and color won't fade
monty2003
Oct 19, 2020 07:51 PM
mizfitg37s
Jul 1, 2016 01:16 PM
Dough1397
May 25, 2014 10:58 AM
newspider4re
Apr 14, 2013 01:35 PM
