Akebono BBK hardware kit
Old Dec 27, 2017 | 11:38 PM
Granddaddypurp's Avatar
Granddaddypurp
im buying all the parts so i can upgrade to the sport BBK
and i have a question regarding the hardware kit.
referencing this thread for my parts:
https://www.myg37.com/forums/brakes-...the-cheap.html
I bought both the centric hardware kit and the posi quiet pads, which came with a hardware kit. so i have two extra kits...
but i noticed the pins on the front and rear are the same size in both kits. Are the hardware pins supposed to be the same size? or is the rear supposed to be shorter?
Im asking because i read this post on the thread
Originally Posted by celwin
FYI for anyone buying centric brake hardware kit for the Akebonos. The pins that comes with the rear kit are the same length as the fronts. That will cause them to poke out the rear calipers; As opposed to being flush. You will either need to cut them to be flush, or buy the OEM rear pins at substantially more. Cheapest I've seen is $6.16 per pin.
should i buy 4 of these?
https://www.z1motorsports.com/rear-b...in-p-8486.html
Old Dec 27, 2017 | 11:45 PM
PNW_IPL's Avatar
PNW_IPL
Originally Posted by Granddaddypurp
Hows it going everyone,
PosiQuiet Ceramic Front CENTRIC Part # 10513460 ($38 set)
PosiQuiet Ceramic Rear CENTRIC Part # 10513470 ($30 set)
Front kit Centric # 11742053
Rear kit Centric # 11742054
yes.....
Old Dec 27, 2017 | 11:53 PM
Granddaddypurp
Originally Posted by PNW_IPL
yes.....
lol...
so yes the rear is supposed to be shorter?
or yes they are the same size?
PNW_IPL's Avatar
PNW_IPL
lol...
not same size. Front caliper thicker longer pin.
Old Dec 28, 2017 | 12:02 AM
Granddaddypurp
Also does anyone know where to get new calipers at a good price ?
im looking to get the red ones from the q50/q60 redsports
at discountinfinitiparts.com, after core charge and shipping it comes out to over a grand
called my local dealer and the best price he could do was about 1,100 for all four.
thanks. so should i buy the rear ones from z1?
Old Dec 28, 2017 | 12:18 AM
PNW_IPL's Avatar
PNW_IPL
Look for 370z calipers same sbit
Old Dec 28, 2017 | 09:17 AM
Here's a kit that member Overboard found at rockauto.com, might be worth consideration
https://www.myg37.com/forums/brakes-...-calipers.html
Only caveat is reman calipers can vary in exterior condition, some are pristine and some have been banged up which may reflect the final finish coat.
Old Dec 28, 2017 | 11:09 AM
KungFooFireman's Avatar
KungFooFireman
This happened to me as well. I ordered the kits from Rock Auto and the rear pin is the same length as the front and sticks out. I emailed them to see if I could get the correct one and they said they couldn't replace them since I "installed" them. I ordered as indicated on the website for the rears and I still got the wrong item. I couldn't wait 2-3 as I already had everything ready to roll. They do work as I have them in now, they just stick out but they don't interfere with anything so I wouldn't worry too much about it.
Old Dec 28, 2017 | 03:20 PM
Granddaddypurp
wow, thanks i just ordered the calipers from rock auto saved a ton of $$
also got some akebono decals from amazon
hopefully the final finish is pristine ill let you know once they get here
Old Dec 28, 2017 | 05:13 PM
Nice! Definitely update that thread I linked when you get them
jsampsell
May 18, 2015 02:02 PM
connoisseurr
Apr 9, 2015 05:52 PM
Mik3G37S
Mar 22, 2015 02:07 AM
Rayramg37
Sep 7, 2014 05:00 PM
Shurik355
Aug 22, 2012 05:50 PM
