Help Brake rotors.
Old Oct 12, 2017 | 05:39 AM
oakley1984's Avatar
oakley1984
Brake rotors.
So ive done endless reading in the forums here, elsewhere, and anything else i can find online... found lots of info, and am fairly positive of whats needed for my vehicle, just hoping someone else can confirm 100%
not going to try and list all possible configurations as ive found they deff vary depending on package and body style (coupe/sedan)
my vehicle is a 2011 g37xS coupe, has 4 piston calipers up front and 2 piston calipers in the rear, came stock with 19" wheels.
From EVERYTHING i can read and research, it Should have 355mm rotors in the front and 330?mm rotors in the rear?
just looking for confirmation or a link to a credible source to learn
thnx
Old Oct 12, 2017 | 10:32 AM
The Sport Akebono brake package has 355mm front 350mm rear rotors, the 330mm rear rotors are for the base coupe setup.
For a link that may help, here you go~
https://www.myg37.com/forums/brakes-...the-cheap.html
