Tein S Tech lowering springs
Old Sep 14, 2017 | 01:17 AM
Bossman's Avatar
Bossman
I'm looking into getting Tein S Tech lowering springs. I heard I need a front and rear camber kit on my 08 g37s coupe. Car will be dropped 1.5 inches. Do I need a camber kit?
Old Sep 14, 2017 | 08:53 AM
Car will be dropped more than 1.5" on S techs, they are a deep drop spring. If you want a drop where you "should" be able to get by with only a rear camber kit look into Eibach or Swift springs.
If you get S Techs you really should get the full F&R kit, but some don't and just buy tires more often.
For a couple hundred more I'd just get Tein Basis Z coilovers, you can get just the height you want, and if you stay on the milder side that rear kit "may" be all you need.
Old Sep 15, 2017 | 09:20 PM
xxg00w0's Avatar
xxg00w0
S-tech is lowest springs you can get for our cars(I think)
If you don't want to change your rear tires every 8k miles get rear camber kit
my car with S-tech with 20mm spacer in the front, 5mm spacer in the rear
@XXG000W0
Old Sep 15, 2017 | 09:41 PM
H&Rs are even lower springs, but yeah, the S-Techs are a serious drop ^^^looks nice though!
Old Sep 15, 2017 | 10:24 PM
Kpmikey808's Avatar
Kpmikey808
How's the ride &'clearance
@XXG000W0
How's the ride on those tein s
Do u scrape any at all
Did u keep oem shocks or go after market
After springs settled what was fender to ground measurements
I was about to buy those tein s springs
I bought the tein basis coilovers- they are nice - but can be bouncy here & there
I'm about 26.25-26.5 FTG
On certain bumps shock or nut will knock under car
Old Sep 16, 2017 | 03:06 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Your #1 Infiniti Vendor!
Contact us for pricing on springs!
-Josh
Old Sep 18, 2017 | 07:45 PM
saywat?'s Avatar
saywat?
weird im at 26 all around and mine is not bouncy and makes no noise
Old Oct 6, 2017 | 05:47 PM
Bossman's Avatar
Bossman
I did not see all these comments but thanks.
Old Oct 6, 2017 | 05:50 PM
Bossman's Avatar
Bossman
Also does anyone know any affordable camber kits for the G37? I'm thinking about running eibachs and getting a rear camber kit.
Old Oct 6, 2017 | 06:00 PM
xxg00w0's Avatar
xxg00w0
Spc ..................
Old Oct 6, 2017 | 11:16 PM
saywat?'s Avatar
saywat?
If u want affordable there's tons on eBay made in China all different colors probably same factory. Do I recommend? IDK no ones brave enough to try lol
Old Dec 11, 2017 | 01:26 PM
Javilowks's Avatar
Javilowks
How do you think some 18x10.5 in s tech would be?
I have 18x10.5 wheels and I bought s tech which I haven’t installed should I sell them and buy better ones or how would the ride be ? Pics ? I couldn’t find none
