I need to increase the height of my car
Old Jul 21, 2017 | 11:01 PM
Originally Posted by Vizard_87
Yeah mine go waaaay higher than oem height, i use that preset when i go up my driveway
So now here's an awesome (and expensive) upgrade answer to the OP's problem, House vs. Car.
What's he going to do?
Old Jul 24, 2017 | 09:44 AM
atlg37ss's Avatar
atlg37ss
For now, I am just gonna go snake like up and down the drive way until we have better and cheaper solution. Probably getting my muffler tip swap out for something smaller in the near future.
Old Jul 24, 2017 | 09:55 AM
OP, is that a drain between your driveway and the road? If so, it is what it is. If not, then flatten out the angle with cement or cold-patch.
Another bit of advice: K-turn in your driveway and exit front-first at a big angle. Trying to back out perfectly is nearly impossible. I never, ever back out of my driveway. Guaranteed I would crush an exhaust tip if I did that.
Also, you have a really wide tapered corner on both sides. Use that to your advantage, because from your pics here you're not.
Old Jul 24, 2017 | 11:01 AM
atlg37ss's Avatar
atlg37ss
There is a drain between the driveway and the road but HOA is not allowing it to be tempered in anyway.
Old Jul 26, 2017 | 11:58 AM
r2dmax's Avatar
r2dmax
Yeah, you definitely need to angle a bit more. You have 2/3 of your entrance you aren't using to your advantage to get in. I still say you should back (reverse) in at a deep angle. It will be much easier. Has been on mine and I've always lowered or slammed my cars
Old Jul 26, 2017 | 10:56 PM
dbeachy1's Avatar
dbeachy1
Is your car really OEM height?? The rear, at least, looks like it's at least 1" (and more like ~1.5") below OEM: in the final picture, the left-rear tire is up inside the fender on fairly level pavement.
Old Jul 27, 2017 | 03:09 AM
Ricio1991's Avatar
Ricio1991
Just go sideways man! I mean I always do but my driveway is not that steep. If your at stock height then there's nothing else you can do your driveway must be really steep
Old Jul 27, 2017 | 03:12 AM
Ricio1991's Avatar
Ricio1991
His sedan definitely looks lowered! No way it's at stock height unless the wheels make it lower but I have stock 17s with swift springs and it's not even that low lol
