Brakes & Suspension Reviews on brakes & suspension for G vehicles.
Review Tein Street Basis Z
Old Jan 2, 2019 | 10:48 PM
  #31
jpowersjr2's Avatar
jpowersjr2
I am getting ready to install these on my coupe. Did you need a spring compressor? I saw in another thread where 4DRZ had to use a spring compressor to remove the stock front top hats. The videos/tutorials I've seen didn't mention one, however they were of different coilover brands.
EDIT: Where can I buy replacement front top hats? One of my bolts got f'ed during my strut brace install somehow...
Old Jan 3, 2019 | 12:17 AM
  #32
jpowersjr2's Avatar
jpowersjr2
After doing some research I will need a spring compressor.
FYI the front top strut mount is 54320-1EA0B and gasket is 55338-EG00A
Old Jan 3, 2019 | 01:13 AM
  #33
jpowersjr2's Avatar
jpowersjr2
I think I'm just going to end up buying a used strut and pulling of the strut mount. Much cheaper than buying a new one. Plus it would bug me having one new and one old mount so I would probably end up buying 2 lol, which would be almost $200. So if I can get this used strut for about $50 then I'll be set (as long as the threads are in good shape). Another idea, maybe the bolts are replaceable?
Old Jan 4, 2019 | 12:08 PM
  #34
SilverG37X604's Avatar
SilverG37X604
hi i was thinking about going with these but i heard some people had issues with using the stock top mounts is this true?
Old Jan 4, 2019 | 12:18 PM
  #35
Bommerang's Avatar
Bommerang
I didn't use spring compressors when I installed these on my friends car, granted we had an impact gun (battery, not air) and just held the shock down and the spring barely even energy held in it to recoil when we took it all apart. But reassembling the strut I just had my friend hold it down while I impact gunned the top not to secure it all down. The safest route and especially needed if you don't have an impact gun is to use spring compressors.
No issues here as the main goal is to reuse the stock top mount, unless there is some specific problem you've heard people having.
Old Jan 4, 2019 | 03:59 PM
  #36
jpowersjr2's Avatar
jpowersjr2
Yeah the only problem I could think of people having would be if the stock front top mounts had stripped bolts or the rubber bushing/insulator was bad. Should be a direct swap and you'll reuse the stock gasket as well.
Old Jan 9, 2019 | 01:03 AM
  #37
SilverG37X604
i have just heard its been making noise?? any issues recently to noise or anything?
Old Jan 17, 2019 | 01:28 AM
  #38
jpowersjr2's Avatar
jpowersjr2
No noises on mine so far but it's only been a day lol.
