Need rotor and brake pad help for G37S
Old Jul 18, 2017 | 10:19 PM
xnick101's Avatar
xnick101
Originally Posted by Silver37
Thanks. I need new rotors on the front and may consider these.
Question - do any of the aftermarket pads not squeal when backing up like the stock Akebonos do? The stock pads have always started to do this once they get a few miles on them, and I'd love to get rid of that issue.
Not sure. But my stoptech's squeal when I back up.
Old Jul 18, 2017 | 10:28 PM
Victory's Avatar
Victory
I have no issues using akebono brakes. Reinstall using fresh hardware and plenty of brake lube.
I also find most warped rotors aren't warped and they don't need resurfacing. Rust forming where the hub annd rotor mate is definitely the biggest culprit. Whenever i install new brakes on my car i make sure to scrub the rust off the hubs mating surface and apply a bit of brake grease to prevent corrosion.
i suspect most mechanics getting paid book rate aren't scrubbing your hubs with scotchbrite and tightening your lugnuts to 80 ft/lbs
Old Jul 18, 2017 | 10:30 PM
Silver37's Avatar
Silver37
Thanks. Must be the overall design that keeps the dust in and that contributes to the issue.
Old Jul 19, 2017 | 11:53 AM
Victory's Avatar
Victory
Aside from lubricating all the contact points, you might consider anti-drag clips as well
Old Jul 28, 2017 | 08:14 PM
Surfnazi's Avatar
Surfnazi
I have the full stoptech kit on 2 g37s coupes no squealing and better stopping.
