Best budget coilovers?
Old May 14, 2017 | 07:35 PM
saywat?'s Avatar
saywat?
The tanabe front matches the stock rear. U can do that. And sell the tanabe rears to someone with eibaachs bc it matches them better. If u go tanabe front n stock rear no camber kit needed at all
Old May 15, 2017 | 08:58 AM
CharlieMac646's Avatar
CharlieMac646
Sounds like all you need is a rear camber kit, no need to switch suspension unless it's going bad or uncomfortable or you're not satisfied with the height. Even if you switch to the Tein Basis coilovers, you might still need a camber kit depending on the height you set it to.
Thanks, what height should I aim for to eliminate the need for a rear camber kit ?
Old May 15, 2017 | 09:45 AM
MaQG37's Avatar
MaQG37
If you spend a little extra, you can get the Tein Flex Z and you get dampening along with the ability to get them re-built easier. I had them for a few months, great coilovers for the price.
Old May 15, 2017 | 02:03 PM
JM Auto Racing's Avatar
JM Auto Racing
MYG37.COM Sponsor
Agreed!
If you are going to go with the Tein - Spend the extra for the Flex Z
Old May 15, 2017 | 02:48 PM
saywat?'s Avatar
saywat?
rebuilt now means u can order shocks seperately to replace worn shock. they no longer revalve the shock and send it back to u.
Old May 18, 2017 | 04:05 AM
dbj3ff's Avatar
dbj3ff
Tien coilovers are best budget coilovers. They ride very good and smooth. Only downside is that the rear does not get low enough.
Old May 18, 2017 | 09:43 PM
MaQG37's Avatar
MaQG37
That's easier than having to send them back in..Even at a price premium. I'd rather have my car back on the road sooner.
