Many dash lights on
Old Dec 9, 2016 | 04:15 PM
tbssimp's Avatar
tbssimp
Originally Posted by Elco
The key light on the dash indicate a problem with your steering lock system on the car. That steering lock make's lot's of problems on other nissan car's that use the same electronic steering lock system (370Z, GTR, Juke, etc...).
Disabling the steering lock will fix the key light issue on the dash. There are lot's of threads on 370Z forums, GT-R forums and even on this forum regarding the steering lock module issue.
The TPMS light is related to an absent, out of sync TPMS sensor or a TPMS sensor with a dead battery.
Ok thank you. I just changed the battery in the key and the light is still on. I will look into the steering lock module.
I'll have them look into the wheels. Any idea why the traction control is still comes on when I am just driving it normal?
Old Dec 12, 2016 | 12:35 PM
tbssimp's Avatar
tbssimp
OK I have some updates on these issues. I double checked my break fluid and it was a little low (right at the min line). I filled it to the max line and both the brake light and the traction control light also went off. I read on a forum that low brake fluid can cause both lights to come on and that was the case.
I still have the tire pressure light on but I think that is because of the aftermarket wheels but I will have my shop confirm that.
I changed the battery in the key fob and the light is still on. I am still having issue with that. I don't know that it is the senor because the light isn't red it's yellow and after reading on a few posts that issue often triggers the red light to come on.
