Brake Booster Warranty Replacement
Old Nov 22, 2016 | 10:04 PM
GLife14's Avatar
GLife14
In for first service since ownership and mentioned a slight noise when applying the brake pedal. Was able to replicate the issue when the car is in Park. Thought it was no big deal since only real issue was the noise... But I did get call and said its a brake booster. Just shocked something like this would go bad with only 16k miles.
Haven't read about anyone complaining about this issue. Should I be concerned or it is just one of those things that go bad?
Either way, glad it will be taken care of...with fresh brake fluid as well
Old Nov 23, 2016 | 03:39 PM
isosunrise's Avatar
isosunrise
I believe I had mine replaced through Infiniti elite warranty at 56k. Should be fine
Old Dec 9, 2016 | 08:08 PM
GLife14's Avatar
GLife14
Just had it replaced and now I'm hearing a click noise when coming to a stop as well as the same brake pedal noise I had to begin with...Dealer invoice stated replacement of brake booster and bled the brake system.
Definitely worse than before since the noise was limited to the brake pedal and only heard in the cabin. Going back monday...
