scraping issue
Old Nov 12, 2016 | 05:19 PM
timc00k's Avatar
timc00k
scraping issue
I recently bought eibachs from Kenny and I absolutely love the new look.
One small issue, I seem to be scraping when I pull up to my parking spot. When I took the car to alignment earlier today, it appears that I am not scraping my engine splash guard but rather the muffler. The drop isn't drastic at all.
Exhaust isn't leaking but (a) do I live with this issue and slowly pull up and let it scrape? or (b) go back to OEM springs or
Are there any significant impact from this? I have not noticed anything.
Old Nov 12, 2016 | 05:40 PM
My Y-pipe looked 10x worse and it still doesn't leak (amazed). Just take any steep drives at a good angle rather than straight at it and take it real easy over speed bumps, going over those at an angle helps too. You'll get much better at avoiding scrapes as you get time w/ your lowered G. Don't get too worked up over it. I'll see if I can find some pics of mine on the site, you'll be floored
Old Nov 12, 2016 | 05:44 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
my car scrap's all the time..my my muffler looks way worse than that..
Old Nov 12, 2016 | 09:30 PM
Here you go Tim, this was when I was dumped on B&G springs, about 25.75" to the fender arcs (am about a 1/2" higher now on coilovers). You'll be fine
Old Nov 12, 2016 | 11:23 PM
Ricio1991's Avatar
Ricio1991
Like everyone else said you'll be fine. You will learn adjusting and angle better on driveways and speed bumps. It takes time to get used to
Old Nov 12, 2016 | 11:42 PM
Ape Factory's Avatar
Ape Factory
True story. I have a similarly steep driveway and under normal circumstances, even with a full tank of gas, I would not scrape even though I'm lowered. I was hosting a Russian Journalist late this summer and she was very close to me in height (6'3") and I'd scrape something fierce with her in the car. Moral of the story, don't let Russian journalists ride shotgun. Just saying.
Blnewt, your exhaust looks horrible! If I had the means, I'd buy you all the Argotsa cup suspension so it wouldn't be an issue.
I'd consider rounding off the sharp edge on the driveway where the interference occurs.
Old Nov 13, 2016 | 12:14 AM
All that damage was done when I was slammed a 1/2" lower, I don't have any issues now that I'm up to 26.25" at the fender arcs
Old Nov 13, 2016 | 01:29 PM
xnick101's Avatar
xnick101
I have the same issue. My car won't go into my driveway if I try. I have to get the front of the car onto the driveway and then pull a hard left and get it in. If I don't my bumper gets stuck and my wheels push again the fender. So try going into the driveway at an angle, so come in from the side and pull a hard left.
Old Nov 13, 2016 | 07:24 PM
timc00k's Avatar
timc00k
Thanks all. It gives me some comfort knowing it's not a big deal and these little issues are expected when riding the 'lowered' life
A lot of the bumps that I felt with OEM feel more dramatic and loud with being lowered. I am still getting used to it to be honest.
Old Nov 16, 2016 | 10:33 PM
g35g37fan's Avatar
g35g37fan
Ive been lowered for exactly a month and I am having a same issue! I feel like those flanges are way lower than the muffler for no reason.
Does anyone with aftermarket exhaust still have a scraping issue?
Old Nov 16, 2016 | 11:31 PM
What are you dropped on? If it's a 2" or less drop you should be able to minimize your scraping to the point where it's a very rare occurrence. There's a point where you drop it too low for some obstacles and scraping is inevitable. I WAS at that point where I was too low and was scraping pretty often, when I got coilovers and raised it to zero gap, about 26.25" to the fender arcs I rarely have any issues. And it's so much nicer to drive without all that stress
Old Jul 19, 2017 | 10:59 PM
aragon__12's Avatar
aragon__12
i just lowered my G and i'm having a little issue with my Tomei exhaust scraping on steep entrances. I am thinking of buying a heat wrap and covering the part that scrapes but I'm not sure if that will work.
