Rear left can't be aligned
Old Sep 15, 2016 | 09:43 AM
Marionan's Avatar
Marionan
I had an alignment done a few weeks ago to get the camber back towards 1-1.5 for tire wear reasons, and the front was all good, same with the passenger side rear. However on the driver side rear, the guy at the shop told me that they tried, but they can't get it into spec. He basically said that when he reduces the camber, the toe must increase, as "something must be bent back there I'm not sure." So, the camber is at 1.3 and the toe is way out of spec at 1 degree (should be .15). Anyone have any idea what could be bent or what needs to be replaced?
Could this be why the car vibrates between 60-80 even after alignment and balancing?
Old Sep 15, 2016 | 09:45 AM
Kris9884's Avatar
Kris9884
I would at least get the toe into spec or you'll tear through tires. Probably a bent rear camber arm, they are super cheap if you buy used OEM. If you're lowered you might as well order aftermarket for more adjustment though.
http://www.ebay.com/itm/07-09-Infini...fiQMvQ&vxp=mtr
OR aftermarket -
http://topspeedauto.com/infiniti-g37...harden-rubber/
Old Sep 15, 2016 | 09:52 AM
Marionan's Avatar
Marionan
Thanks! I have the rear camber arms from SPC isn't that the same thing?
Originally Posted by Kris9884
I would at least get the toe into spec or you'll tear through tires. Probably rear toe arm, they are super cheap if you buy OEM.
Old Sep 15, 2016 | 01:49 PM
If you're lowered you'll also need the rear SPC toe bolts w/ elongated slots, won't be able to get camber & toe correct without it in most cases. If you do have the new arms & bolts (w/ the elongated slots) they should be able to get it corrected, even if the arm is bent since it can still be adjusted, unless it's a severe issue. G/L
Old Sep 15, 2016 | 03:07 PM
Marionan's Avatar
Marionan
Ohhhh okay so i need the bolts in addition to the arms? That would make more sense because i don't remember ever hitting a pothole or anything strong enough to bend a suspension component. Thanks
crazieight
Aug 8, 2020 03:16 PM
wmvG37
Sep 4, 2016 07:10 PM
VQHAY
Sep 3, 2016 08:41 AM
G37X GraSdadow
Aug 29, 2016 04:43 PM
plando
Buying & Leasing
Aug 22, 2016 06:32 PM
