Good idea or not
Old Aug 7, 2016 | 10:50 AM
celwin's Avatar
celwin
Good idea or not
I currently dropped on Tanabe springs. I am satisfied with the front, but the rear is a tad to low for my liking. One side is slightly more lower than the other. I was thinking of leaving the front springs and swapping out the rear sprints for rear tanabe coilovers? Is this a sound option? Expense is a consideration; hence the reason not wanting to swap out the fronts.
Old Aug 7, 2016 | 11:19 AM
Is your G RWD? If so I'd look in to Tein BasisZ coilovers, this newest version is no longer serviceable (shocks able to send to factory for rebuilding) so the price has dropped quite a bit, sets for under $500 shipped have been reported.
Here's one example, it doesn't list current G sedans but it fits them as well
Tein Street Basis Z Coilovers for the 370Z / G35 / G37 at KamiSpeed.com
Old Aug 7, 2016 | 03:45 PM
celwin's Avatar
celwin
Yes it's RWD. that link you provided has the min drop in front as 1.4. Lower than my current front drop on tanabes.
Old Aug 7, 2016 | 04:38 PM
That's in the recommended range but the whole adjustment range is quite a bit more, here's the list, you would have room to go higher for sure, and just a little higher won't be a problem
TEIN USA | COILOVER KIT & SPRING KIT SEARCH ?INFINITI?G37 COUPE?2008+?STREET BASIS Z
You might shoot a pm to 4DRZ and see what he says as far as height range.
Also you could just use the rears and keep your front springs, that's what Rochester has w/ Swifts in front and Tein coils in back.
Old Aug 10, 2016 | 06:45 PM
saywat?'s Avatar
saywat?
if u gonna do all that to the rears why not just put it in the fronts too and sell the tanabe springs as a set
Old Aug 10, 2016 | 07:48 PM
SlateBlue G's Avatar
SlateBlue G
all spring will sag more in the back. Only way is to go coilovers
defektion
Sep 25, 2017 02:58 AM
zib331
Jun 3, 2016 10:03 AM
g35g37fan
Mar 30, 2016 08:09 PM
