BC racing coilovers thoughts?
Old Aug 4, 2016 | 04:39 PM
slotterjordan's Avatar
slotterjordan
I picked up a pair of bc racing coilovers. Any thoughts? Should I get wheel spacers? How do they ride. Any feedback is great. Thank you. Main concern is wheel spacers
Old Aug 4, 2016 | 07:22 PM
They will be firm once you get them set up, I'd wait until you get just the drop you want then decide just how much spacing you want.
Old Aug 4, 2016 | 07:26 PM
slotterjordan
Yeah that sounds good. Definitely. How low can you go till. You start rubbing
Old Aug 4, 2016 | 08:06 PM
I'd shoot for zero fender gap, this will be about 26.25" to the upper fender arcs. I've been lower than that and it's not much fun IMO.
Old Aug 4, 2016 | 09:57 PM
slartibartfast's Avatar
slartibartfast
Read all about them in the suspension forum.
Old Aug 5, 2016 | 12:41 AM
Pray that you don't end up with their infamous clunking noise in the rear. BC coils are ridiculously known for it.
Old Aug 5, 2016 | 11:10 AM
Tachyon's Avatar
Tachyon
They still haven't fixed that??
Old Aug 5, 2016 | 12:04 PM
reNeglect's Avatar
reNeglect
Usually comes from the rear, so what im assuming its because of the rear spring bucket vs a true coilover setup. the spring bucket i dont think you can set the proper preload depending on your ride height.
Old Aug 5, 2016 | 01:37 PM
JM Auto Racing's Avatar
JM Auto Racing
MYG37.COM Sponsor
With the newer releases of these coilovers that problem has pretty much stopped.
We just installed a set a month ago and our normal procedure here is to follow up with all customers 30 day after install to make sure everything is going great. NO problem reports thus far.
Old Aug 5, 2016 | 08:33 PM
reNeglect's Avatar
reNeglect
mines was the same, had two sets of my old car. The new set did no squeak at all until about 6 months later...
Old Aug 5, 2016 | 09:38 PM
beachbum718's Avatar
beachbum718
Pull them up on a lift and tighten all lower bolts of the coils with the cars weight on them after install.and no noises will be heard.
May 10, 2016 10:59 AM
