Finally Solved Brake Judder... I hope!
Old Jul 17, 2016 | 10:56 PM
taverty's Avatar
taverty
I've had a pretty consistent brake judder since I purchased my G37S back in 2012. I think I finally solved it. I replaced the hubs, rotors and pads on both side in one swoop.
I replaced both sides with Timken hubs, Centric premium rotors and Akebono ProAct pads.
When I replaced the hubs I took extra time to make sure the mounting service of the hubs were perfect and got a runout of 0 on the hubs. Then I mounted the rotors and got them to 0 runout as well. I was never able to get a 0 runout on rotors mounted to my old hubs no matter how hard I tried. I always got under the maximum runout, but never 0. I haven't had any judder in almost 10,000 miles. Which is truly a record for me, I usually get it back less than 1,000 miles after changing the rotors/pads.
So if anyone else is dealing with a persistent judder at highway speed try replacing the hubs. Make sure to clean up the contact surface on the car and heat shields.
Old Jul 17, 2016 | 11:08 PM
ZahyMatar's Avatar
ZahyMatar
Definitely looking forward to upgrading my brakes now! I've dealt with brake judder for the longest time.
Old Jul 18, 2016 | 12:01 AM
Good to know about the Timken hubs, that's the one thing that typically isn't addressed for those that can't find a cure for the recurring judder.
I always take my time to get rid of any buildup between the hub/rotor and rotor/wheel mating surfaces.
What did the hub replacement cost?
Old Jul 18, 2016 | 06:52 AM
taverty's Avatar
taverty
Cost break down for everything:
Timken Hubs (2): HA590376: $189.60 (RockAuto.com)
Centric Rotors (2) 12042100: $133.58 (RockAuto.com)
Akebono ProAct (1) ACT1346: 54.85 (Amazon.com)
Smooth running brakes at highway speeds: Priceless
At the time I had a 10% off RockAuto.com coupon. Search around you can usually find them online.
Honestly, the Timken hubs looked to be better quality then my OEM hubs.
Old Jul 20, 2016 | 04:35 PM
micafd3s's Avatar
micafd3s
goin to stoptech rotors and hawks street pads eliminated my judder...
Youkickmydog24x
Mar 30, 2016 02:29 PM
tayjet5
Mar 29, 2016 01:52 AM
carid
Supporting Vendors
Mar 25, 2016 07:21 AM
