Eibach Springs + spacers review
^ so you removed the spacers and springs and reverted back to stock because those mods were deteriorating the life of your tires?
I think some people get an alignment and camberkit which solves the problem?
I have -2.3 degrees of camber in the rear, -1.9 (i think) in the front, and i literally have no camber wear at all after almost 10,000 miles. Having a little bit of camber doesn't kill tires, having the toe badly off does.
Yeah, a proper alignment was his only issue. Camberkit would have helped too.
what is the recommended specs?
is the goal to achieve 0 toe? I know nothing about alignment.
Although my fronts aren't as consistent to one another as yours are.When I removed the summer wheels for winter, I was expecting my rears to be trashed after 10k miles (or thereabouts)... but nope. Still more life in the old shoes.
For AWD Sedans the Swift springs seem to get the best overall reviews and they have a nice even drop. AFAIK Koni doesn't have the front struts for AWDs. There's also decent coilover options from KSport, Fortune 500, and Stance.
I read on here there is an issue with some of the coilovers in the rear making a clunking noise, how true is this?
Nice to know you're doing your homework, and welcome to the site BTW
Nothing at all wrong with -1* camber (or -2*, for that matter). I wouldn't get all worked up about that.
Last year, blnewt directed me towards Tein Basis coilovers to replace my Swift springs. For what I was trying to accomplish with the rear of my car, it was solid advice from one old guy to another...
...to another, LOL.
...to another, LOL.
- Will I need the camber arms with coilovers?
- Do you have them (yes/no) and what are the results?
I don't have the money for both, so do you recommend doing wheels/tires or coilovers 1st?
I needed the rears. So... maybe yes. I would even go so far as to say probably yes.
I still haven't replaced hardware in the front because I'm still using Swift lowering springs up there, because the height is right, and the handling is balanced. (Front CO's are in the attic.) When the CO's do go on the car up front, I'll be replacing the control arms, too. At the moment, I have a full 1/2 degree camber discrepancy left-2-right on the front wheels. Not happy about that, but not losing sleep over it either.
Do the suspension first. Reason being, you'll be in a better position to figure out wheels and offset after dialing in the height you want with the suspension components you want.
That said, your OEM wheels are going to look silly dropped and tucked. Consider a set of spacer adapters until you get wheels. I use 15mm wheel spacers in the winter, and take them off in the Spring. It's an annoying little dance, but necessary. We'l, maybe not "necessary" per se...
Similarly, aftermarket rims are going to look silly without the drop or flush fitment. But the other approach is more easily fixable for less cost. Wheels and tires can be a huge expense, more so than the suspension parts you have there.
I do agree and was thinking similarly about suspension vs wheels. I normally do suspension 1st, or gather it all for a nice "transformation".
If you use a set of wheel spacers in between plans for suspension mods and aftermarket wheels, keep in mind how easy it would be to sell the spacers with a pretty good recoup of the original expense, which would only be around $200 anyway.
First things first... mess with your suspension and then reassess things. Bear in mind, this was not the advice I took some years back. First I bought the wheels, and it looked so wrong that I dropped the car a month later. I spent the next year quibbling about the rear fitment, finally buying the Tein Basis kit.
So if you're reading advice here, it's based on what not to do.
Best thing to do is set the ride height first, then get the wheels. I had to put on 15mm spacers to make my aftermarket wheels sit flush, but if i dropped the car FIRST i could have just gotten wheels which fit perfectly. Oh well.
I had Eibach lowering springs as well and for the most part I did enjoy them. First they really do bring the car to the height it's meant to be. The overall ride wasn't too bad either, but I do agree on the back being soft at times.
G37sGraphite
Aug 24, 2016 12:01 PM
G37X GraSdadow
Jun 17, 2016 10:57 AM
dstarke187
May 7, 2016 07:28 AM
