G37x Rotor size help
Old Jun 7, 2016 | 11:16 AM
towerworld's Avatar
towerworld
So my current OEM brakes are almost completely worn and i need to replace the rotors as economically as possible.
My vehicle is a 2013 g37x sedan and I wanted to know what size rotors will fit front and back.
Also, does anyone have any experience with Luk Schaffer Brakes?
https://www.crossdrilledrotors.ca/si...rake-kits.html
nyone have experience with ELINE Rotors from
Canadabrakes.com?
Old Jun 7, 2016 | 11:27 AM
G37xhibeet's Avatar
G37xhibeet
320mm front, 307mm rear
Old Jun 7, 2016 | 12:04 PM
slartibartfast's Avatar
slartibartfast
Brakes & Suspension - MyG37
Old Jun 7, 2016 | 01:26 PM
towerworld's Avatar
towerworld
Thanks,also does anyone have experience with ELINE Rotors from
Canadabrakes.com?
Old Jun 7, 2016 | 04:19 PM
Canadabrakes.com?
Seem to get decent reviews on that site, probably are Centric CTek rotors that are machined, that's a pretty common way to keep the cost down. Should perform about like OEM depending on the pads you select.
If you want a better rotor, the Centric Premium Rotors have better venting and rust control, and if you want them slotted the Stoptech Drilled &/or Slotted would be a good option.
If Rockauto.com has Canada based options might give them a look. Also if you go to rockauto to get part #s then cross shop on amazon.com you might find better deals, just not sure how that applies to Canada customers
masterdukill
Aug 26, 2016 02:44 AM
Ace_07
Apr 21, 2016 08:43 PM
Beachbodyg37
Apr 9, 2016 01:17 PM
Beachbodyg37
Apr 7, 2016 08:23 AM
Lamify
Mar 19, 2016 04:30 AM
