Air ride and camber kits
Old Jun 8, 2016 | 05:06 PM
That Dude's Avatar
That Dude
Originally Posted by Slowg37
My offset is +30mm, and yea i shaved the rear brackets... It was taking chunks out of my tires lol. Front camber is completely unnecessary imo. Plus i dont like the look of camber anyway, so if i can save money with out any damage to my car, I'm bout it. Where'd you get your camber kit and tow bolt? Im hurting after buying an OEM IPL bumper lol.
I got the SPC camber arms and toe bolts from eBay for $170, but that was a couple years ago.
Old Jun 8, 2016 | 05:24 PM
I'm actually curious to know what you guys all payed for the install of either your front or rear or both camber kits installed. I got quoted $300 just for the rear camber kit which I thought was a bit high. And recently knew a member in Canada who payed $55usd which sounds pretty low.
Old Jun 8, 2016 | 05:29 PM
VenomGT9's Avatar
VenomGT9
Install yourself then just bring for alignment...?
After removal of stock, set up the new ones to mirror the length of stock and you'll be fine for a short drive
Old Jun 8, 2016 | 06:21 PM
Slowg37's Avatar
Slowg37
Lol, if you don't like the look of camber than having a camber kit will allow you to run less camber (or more if you "like" camber). I'd go w/ the full kit, but the front is at least fully adjustable for toe so you will tend to run better in front than rear on OEM parts.
Stay far away from those Kinetix camber parts, there's been more than a couple broken welds and even worse, the money saved there isn't worth your safety.
If cost is a concern get the SPC bolts and use one set for your camber arm bolts and one set for your toe bolts, this will get you in spec for $50 if you dremel the slots yourself.
The only reason i want the rear camber kit is to get more clearance between the fender walls and the rear tires so that the scraping will stop. Ive driven about 10k miles on my current tires and have not observed any uneven tire wear at all. So to me, getting the front camber kit is completely unnecessary for my situation i feel. So just to be clear, for what I'm trying to do, id just be buying the rear camber adjusters and toe arms, correct?
Thats kind of crazy, I'm pretty shocked Kinetix hasn't been sued and shut down for faulty suspension parts that could potentially kill someone.
Side note- My buddies from high school is the owner/CEO of Cambergang anddddd i don't have the heart to tell him that I don't like his super excessive camber. He probably has the coolest 350z on earth, the camber just kills it for me.
Old Jun 8, 2016 | 06:27 PM
Slowg37's Avatar
Slowg37
Thats more like it, i cant fathom paying $550 plus installation to tuck my tires in a few millimeters.
Old Jun 8, 2016 | 06:37 PM
Slowg37's Avatar
Slowg37
Is this all i need to adjust my rear wheels? and does anyone have any opinions on godspeed? In the Volkswagen world, Godspeed was a decent low cost brand. I never really heard any negative reviews on their products.
For 09 14 370Z 08 14 G37 GTR R35 Godspeed GSP Adjustable Rear Camber Arm Kit Set | eBay
Old Jun 8, 2016 | 06:50 PM
sharkey's Avatar
sharkey
I ran godspeed on my 350z.. it wasnt a bad brand, but it aint good either.
Would i put it on my g37, nope
Old Jun 8, 2016 | 07:00 PM
Slowg37's Avatar
Slowg37
But what is the difference between a bad brand and a good brand. Is there a difference in the ride or just reliability?
Old Jun 8, 2016 | 08:05 PM
If you want a little more camber and keep your toe in spec for the lowest price just do what I said w/ the 4 bolt setup & a dremel job. This will cost $50 and your DIY labor. Without camber kits in a S Tech drop you're probably already in the -2.4 range in back and about -2 in front. I seriously doubt you're getting good wear in back without any help, but
TBH I would just stick w/ SPC camber parts as a starting point and if you ever plan to really max your G then moving up to SPL would be a plan. The other Ebay type sets like Godspeed etc just aren't worth putting yourself (or others) in possible jeopardy IMO.
Old Jun 8, 2016 | 09:40 PM
Slowg37's Avatar
Slowg37
Im just going to go SPC in that case. Its only like a $100 difference, and yea i agree, I wouldn't want to screw over the next owner. I really do appreciate all the input, you guys are the best!
Old Jun 8, 2016 | 09:56 PM
bikezilla's Avatar
bikezilla
I got both waiting for my coilovers :
$512 SPC performance x-axis A-arms (#73005)
$189 SPC Performance x-axis rear camber arm and toe bolt kit (#72262)
xstarpro
Apr 13, 2016 09:06 PM
Dough1397
Mar 29, 2016 10:41 PM
J'sg37s
Mar 27, 2016 07:25 PM
Strongblood8
Mar 25, 2016 06:45 AM
ShuuraRG
General Tech Questions
Mar 22, 2016 03:45 PM
