FSB torque specs question
Old May 28, 2016 | 11:04 AM
Ape Factory's Avatar
Ape Factory
Hey I know this'll get "seen" here a bit more quickly so my apologies in advance.
Looking at the FSB manual through NICO forums, the torque specs are listed and I'm assuming they're the LAST number in the parentheses. So you have usually a larger number first, then the parentheses, a smaller number then the torque number in foot pounds, correct?
Old May 28, 2016 | 01:25 PM
afar1's Avatar
afar1
In the menu, open "GI", general information, see page 5 in the symbols table for the symbols explanations and the torque units. The numbers in the parentheses are torque specs in metric and non-metric units.
Also, pay attention to the color of the torque symbol, white for ft-lb, black for inch-lb; it's all there.
http://www.nicoclub.com/FSM/G37/Coupe/2013/GI.pdf
Old May 28, 2016 | 01:28 PM
slartibartfast's Avatar
slartibartfast
The first number should be Newtons, the second kg-mm and the third ft-lb.
Old May 28, 2016 | 02:22 PM
Ape Factory
You guys rock. Couldn't find the guide but went by other posts where specific torque values were mentioned. Glad to know I used the right specs.
Old May 28, 2016 | 06:28 PM
slartibartfast
Click on the NICO link and load the pdf. Click the little square symbol in the upper left to open the sidebar. This loads thumbnails of each page. Click on page 5. The symbology is at the bottom pf the page and the first entry is your torque symbol explanation. Better read it because there is a white wrench on a black background and a black wrench on a white back ground. One is ft-lb, the other is in-lb.
Old May 28, 2016 | 07:00 PM
Ape Factory
Ok I'll take a look thanks again.
Old May 28, 2016 | 07:06 PM
THIS is a post that deserves a thanks. Good looking out.
Old May 28, 2016 | 07:35 PM
slartibartfast
Agreed. I missed that he wrote of the two symbols.
Old May 28, 2016 | 08:34 PM
Yeah, you really don't want to tighten the brake bleeder screws to 70 ft lbs
Agreed!
Afar1,I went ahead and copied your posts to the Coupe, Sedan, and Vert FSB link threads.
Old May 28, 2016 | 10:32 PM
afar1's Avatar
afar1
Thanks guys, I've learned so much from you guys over the years, especially when I was juicing up my IPL earlier this year for track, just giving some love back.
G37sGraphite
13
Feb 16, 2019 12:16 AM
G37sGraphite
Aug 24, 2016 12:01 PM
prichable
General Tech Questions
May 31, 2016 01:13 AM
jsweaz
May 3, 2016 08:02 PM
