AWD Swift springs help!
Old Apr 9, 2016 | 04:34 PM
MNfiniti's Avatar
MNfiniti
Got the front struts out, compressed the spring with compressors, how on earth do you get the top nut off the shock? for the life of me I can't get it loose!
Old Apr 9, 2016 | 05:49 PM
slartibartfast's Avatar
slartibartfast
There are flats on the side of the shaft end for an open-end wrench. My Mk.I eyeball estimates 11mm. This prevents the shaft from rotating as you work on the nut. Then use a wrench to loosen the shaft nut.
Some people have had luck using an impact drill to loosen the nut without having to use a wrench to hold the shaft.
Best of luck.
Old Apr 9, 2016 | 05:56 PM
Baadnewsburr's Avatar
Baadnewsburr
also put your body weight on it so theres downward pressure to get it loose. it'll pop loose on the first turn. then twist normally.
Old Apr 10, 2016 | 03:06 AM
MNfiniti's Avatar
MNfiniti
Ok, took me a minute, but finally got them! Thanks for the advice!
Old May 11, 2016 | 01:25 PM
Wicked-G's Avatar
Wicked-G
Just got a set and will be installing this weekend. Post some pics!
TVPostSound
Apr 26, 2016 07:15 PM
2doorbryce
Apr 7, 2016 09:16 PM
andrew4395`
Apr 6, 2016 09:08 PM
JUMBO PALACE
Apr 5, 2016 10:01 AM
