need help fast stuck installing springs!!
Old Apr 7, 2016 | 09:30 PM
2doorbryce's Avatar
2doorbryce
I can't get this to line up I've tried just about everythingneed help fast stuck installing springs!!-photo752.jpg
Old Apr 7, 2016 | 09:32 PM
2doorbryce's Avatar
2doorbryce
Old Apr 7, 2016 | 09:37 PM
PNW_IPL's Avatar
PNW_IPL
Originally Posted by 2doorbryce
here's a better picAttachment 119617
Had the same problem. Move jack to the bolt hole to try and line it up. I had to use two jacks one regular and the oem scissor.
Old Apr 7, 2016 | 10:12 PM
Takes finesse. Two jacks is best so that you can manipulate the lower arm and the knuckle independently. Also, a long rod or bolt or even a screwdriver can aid to stick in there and line them up so the bolt will go through easier. Once lined up, start the bolt and tap it with a dead blow hammer. Be careful not to force it and damage the threads while getting it in there. Like I said, patience and finesse.
Old Apr 7, 2016 | 10:22 PM
TVPostSound's Avatar
TVPostSound
Make sure the car has a jack stand under the frame.
Pros use a line up bar, that is a pry bar with a tapered pointed end to wiggle in the hole.
Old Apr 7, 2016 | 10:24 PM
TVPostSound
Also move the jack more to front or rear, as to cause the arm to tilt/twist in a better position.
Old Apr 7, 2016 | 10:26 PM
2doorbryce's Avatar
2doorbryce
still no luck, I can't believe I've been sitting here trying to line up a bolt for 2.5 hours. it's like the control arm just catches the knuckle and then I can't move it anymore, it just raises the whole car. thanks everyone though
Old Apr 7, 2016 | 10:28 PM
AroundTheG37's Avatar
AroundTheG37
Also, to get the holes to lineup I would grab something long (like a screwdriver) that can go through both sides and move it up or down to see exactly where the threads line up with the hole. Takes some patience but it will happen, trust me.
Old Apr 7, 2016 | 10:29 PM
AroundTheG37
You are going to need to push in on the arm as you lift it up.
Old Apr 7, 2016 | 10:50 PM
2doorbryce's Avatar
2doorbryce
finally got it!!!!
Old Apr 7, 2016 | 10:54 PM
AroundTheG37
finally got it!!!!
Old Apr 7, 2016 | 10:58 PM
2doorbryce's Avatar
2doorbryce
I will post pics when I'm finished!
Old Apr 7, 2016 | 11:23 PM
PNW_IPL's Avatar
PNW_IPL
Congrats sir good job.
Old Apr 8, 2016 | 01:39 AM
Congratulations man! This mod will feel even better when completed and everytime you look at it bc you'll remember what you went through trying to get it right! Good job!
Old Apr 8, 2016 | 02:37 PM
VaderK52's Avatar
VaderK52
I took a long screwdriver to mine and a little leg press action, lined up perfect. I can now change both springs out in less than 10 min.
