Non Sport Brake pad install HELP
Old Mar 22, 2016 | 05:35 PM
GrayG37's Avatar
GrayG37
Originally Posted by beniceorbevice
I just went through this as well last week - the one thing that stopped me from ordering the wrong pads was Amazon - when you add a car to your amazon "garage" they know exactly what part # you need. There was 3 websites that i checked (autoanything, summitracing, etc) that gave me the wrong part #'s for the pads, when i went to add them to my cart on amazon, they show a message in red "These won't fit your car" So i did a little more reasearch, turns out i got lucky ordering it from amazon. Also same thing with rotors, i did a lot of research to see which StopTech and EBC rotors will fit my car, even carid.com showed one part # but amazon knew better.
I also ordered the ones that do fit from amazon even though amazon says they do not. If you look at the ebc catalog you can find the correct part number if you know your rotor size, which is 12.6" for the front in a non-sport sedan.
USA_Automotive_Catalogue_2016
Old Mar 22, 2016 | 05:37 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
i have ordered my pads off autoanything in the past and have never had an issue.. if you type in you car and model they give the correct par numbers
Old Mar 22, 2016 | 05:43 PM
GrayG37's Avatar
GrayG37
The issue is regarding EBC brake pads specifically, not any random pad. For some reason, every website that sells ebc yellowstuff does not advertise the correct part number for the infiniti g37 non sport sedan.
Old Mar 23, 2016 | 09:13 AM
G37Xtreme's Avatar
G37Xtreme
Ordering pads and rotors for our cars is a little troublesome.
Sedan vs coupe vs Sport
They all have different rotor sizes and you have to be careful.
IIRC, the parking brake shoes are the only universal on this car.
I'm doing my brakes this weekend...I've got everything ordered and will have it all by Thursday. If I have time, I'll flush the brake fluid as well.
Is there a resource on here that shows the correct flush order? I'm not talking about simply stating "longest to shortest"...I want an exact order. On some other forums for another car, I've discovered that the "obvious" longest to shortest is incorrect as the driver's side front brake happens to have a longer run as it has to go to the ABS module. This isn't apparent and will trip you up if you just glance at the brake line diagram.
Is there an undisputed flush order for calipers on the G37?
Old Mar 23, 2016 | 09:21 AM
This bleeding order per the FSM~
passenger rear, driver front, driver rear then lastly passenger front.
Old Mar 23, 2016 | 09:23 AM
GrayG37's Avatar
GrayG37
This is what I did when I changed my fluid along with pads. No problems yet.
Old Mar 24, 2016 | 09:20 AM
G37Xtreme's Avatar
G37Xtreme
Thanks, that's awesome. I've seen FSMs specify to bleed from longest to shortest, and then give you a brake line diagram and let you figure it out yourself. I like how they spelled it out to eliminate ambiguity.
Old Mar 25, 2016 | 09:05 PM
G37Xtreme's Avatar
G37Xtreme
If I only replaced my front rotors and pads, could my brake pedal have over-travel and feel a bit spongy?
I left work early today so I decided to change the front brakes and rotors. I was pretty meticulous at each step and feel I did everything correctly.
I'll be doing the rear brakes tomorrow.
Using Google, I did find someone on a Mercedes forum with a similar issue. One guy asked if perhaps he had only changed the front brakes as this causes a fluid imbalance. The suggestion was to change all pads and reassess.
Another possibility is over returning the pistons. Is this also a concern with the G?
Post #3
Mushy brake pedal feel after brake pad replacement. - MBWorld.org Forums
Could this also apply to the G37? I haven't done any bleeding so I'm skeptical that air could have gotten in.
Old Mar 25, 2016 | 09:13 PM
GrayG37's Avatar
GrayG37
When I changed my pads and fluid my pedal felt "spongy" at first. But after I bedded the pads in and drove the car next day, the pedal was very firm. Give it another day or two and make sure you have done the bed in procedure correctly. Everyone does it differently, but I did 20-5 mph four times, 40-20 mph four times, and 60-20 mph four times with moderate pressure without coming to a complete stop in between.
By the way, I only changed my front pads, but I did bleed the whole system so I'm not sure if thats relevant to your question.
Old Mar 26, 2016 | 10:43 PM
jomama22's Avatar
jomama22
The ebc yellows have the bedding surface on the brakes that takes quite a few miles to get through. Once that is completely gone then I would do the normal bedding procedure to finalize the pad/rotor surface.
Old Mar 28, 2016 | 10:26 AM
G37Xtreme's Avatar
G37Xtreme
this is what i use
I strongly recommend this tool to all who plan to do their brakes. The c-Clamp works ok on the front, but the rear calipers don't. This tool would have been great to have. Perhaps a 4" c-Clamp would have worked better than the 3" I had.
Does anyone know if this tool above well work on the sport Akebonos? Looking at their design, I can't figure out how it would work as I don't see a cutout on the calipers.
Old Apr 4, 2016 | 07:49 PM
darin1274's Avatar
darin1274
where did u get that tool?
Old Apr 4, 2016 | 07:59 PM
chuckie311's Avatar
chuckie311
right here
Amazon.com: Capri Tools 21006 Disc Brake Pad Spreader Tool: Home Improvement Amazon.com: Capri Tools 21006 Disc Brake Pad Spreader Tool: Home Improvement
Old Apr 4, 2016 | 08:42 PM
  #29
G37Xtreme's Avatar
G37Xtreme
Harbor freight has a similar one for $7.
I bought their compete brake kit for $44 minus 25% coupon.
Mike@Czp
Interior/Exterior Items
138
Sep 18, 2023 09:04 PM
smitty37g
Mar 22, 2016 12:59 PM
GrayG37
Feb 21, 2016 05:52 PM
rm2342
Intake and Exhaust
Feb 13, 2016 10:54 AM
HS125
Feb 11, 2016 11:27 AM
