SPC rear arm/toe with two part numbers?
Old Jan 9, 2016 | 08:13 PM
HS125's Avatar
HS125
I'm new here and have been following for a couple years. I'm looking at dropping my G37X a little.
Anyway...can they make it any harder to understand just what is needed to adjust the rear camber on these cars!! G35, or G37? Straight or bent? With arm and bolt or just a bolt...or arm, bolt, and plate? Sway bar...stock or aftermarket? I also read that the Eibach camber lit is the same as an SPC! WTH!!
Old Jan 10, 2016 | 12:43 AM
Mr_Mer's Avatar
Mr_Mer
Direct from SPC customer service:
"72280 is the older part number and the newer number is 72260. This will work on the G37 as well and it comes with the toe bolt as well."
Old Jan 10, 2016 | 01:18 AM
HS125's Avatar
HS125
So the new arm is the straight bar...that hits an aftermarket sway bar on a lowered car.
Old Jan 10, 2016 | 08:23 AM
Mr_Mer's Avatar
Mr_Mer
That seems to be the case.
PongSanity
Dec 15, 2016 03:20 PM
bri
Jan 25, 2016 02:20 PM
mjnoles1
Jan 4, 2016 08:43 PM
R3M1NGTON
Dec 31, 2015 06:19 PM
Victory
Dec 31, 2015 12:21 AM
