Strut mount issue and installation
Old Oct 8, 2015 | 01:14 PM
desertmike680's Avatar
desertmike680
Hey guys,
so what are they symptoms of worn out strut mounts and what is installation like of new ones? With that, I'm experiencing some harshness when going over bumps or anything else in the road, and Infiniti stated that the cause of this is related to the mounts.
Thanks!
Old Oct 8, 2015 | 02:39 PM
-SnowMan-'s Avatar
-SnowMan-
Look at your struts in the wheel well and see if they are leaking oil.
Old Oct 8, 2015 | 03:25 PM
si_driver's Avatar
si_driver
strut mounts can leak?
news to me
Old Oct 8, 2015 | 03:27 PM
-SnowMan-'s Avatar
-SnowMan-
news to me
Really? Yes. They have oil and gaskets in them that can leak. Mines been leaking for a while and has oil all over. Planning on replacing them and springs in December.
Old Oct 8, 2015 | 03:42 PM
They're not cheap either IIRC they run about $90 each.
Old Oct 8, 2015 | 03:59 PM
-SnowMan-'s Avatar
-SnowMan-
More than that.
Tokico HP Shocks & Struts - SHIPS FREE - AutoAnything
Old Oct 8, 2015 | 06:21 PM
I'm just talking about the top mounting hat, not the shock.
Actually looks like it's around $75 each
http://www.discountinfinitiparts.com...&siteid=215255
Old Oct 8, 2015 | 06:44 PM
desertmike680
So if the strut isnt leaking oil and is obviously in good shape, then is it normal for the strut mount/hat to wear out and need replacing? Infiniti said the mount has a rubber base which can wear out and cause these noises I'm having. Also, if the hat/mount has to be replaced, does it mean the spring needs to be decompressed to do so?
Old Oct 8, 2015 | 10:56 PM
Yes, it is something that can wear, not sure how common it is as far as having to replace them. And yes, the spring will have to be compressed to R&R.
Old Oct 8, 2015 | 11:23 PM
SpeedBallDEVIL's Avatar
SpeedBallDEVIL
The strut would leak hydraulic fluid if it is bad and you could visually see the leak. Typically it will look grimy as brake dust and debris will cling to it.
You can also try the bounce test. If you haven't heard of it, search for it on google.
Old Oct 9, 2015 | 08:01 AM
si_driver's Avatar
si_driver
I know that struts can leak, but strut mount is what I and the OP were referring to...
Old Oct 9, 2015 | 11:33 AM
desertmike680
Hmm..interesting. Ok thanks!
Old Oct 10, 2015 | 03:34 AM
-SnowMan-'s Avatar
-SnowMan-
Yeah I read that as he was having an issue mounting the strut and installing it properly. My bad.
Old Oct 12, 2015 | 05:05 PM
desertmike680
Well, I'm getting excessive road noise and going over bumps is really harsh, so I was told the strut mounts are shot. With that, does the spring have to be decompressed in order to complete the install of the strut mount?
Old Oct 12, 2015 | 08:00 PM
Yes, autozone lets you have them for free, just have to make a deposit and return them in 24hrs if you weren't aware. Also grease the threaded spring compressor sliders real well and use an air impact for best results.
allen88909
Southern California
Mar 8, 2016 04:12 PM
ScorpionGeo
Nov 3, 2015 09:51 PM
BurtoN86
Oct 28, 2015 07:56 PM
Steveoh187
Oct 9, 2015 04:23 PM
SheLLz
Oct 6, 2015 08:09 PM
