Stop tech BBK, sway bars, and strut bar; installed
Old Sep 15, 2015 | 11:10 PM
  #31
2012G37's Avatar
2012G37
If you didn't apply caliper grease to all the metal on metal contact points (pad backing plates, pad clips, any pins, etc) that could be the culprit.
CRC is good stuff~
Shop did that again. I'll see how it goes, should come close to 500 miles on sat. I'll just prepare for new pads. Maybe get it done with the Rhfc, I did read that someone on here had the same issue in the front, but they had hawk's pads.
Still happy with the upgrade that the shop did for me. As they say, "you pay to play."
Old May 21, 2016 | 08:05 PM
  #32
2012G37's Avatar
2012G37
Kinda late, but after several thousands of miles and a months, I am satisfied with this upgrade.
1st week of December, i swapped the right rotor and decided to change the front pads, which were street performance (came with the kit).
Not sure if the rotor was a defect or the shop didn't bed them correctly. This new rotor came in two pieces and had to be assembled.
New pads worked well, and not much bedding was needed. Brake dust is less than the street type. The rear still has street pads. When needed I'll used these new pad types in the rear..
Old May 21, 2016 | 08:29 PM
  #33
Glad to see you checking in, and sounds like you're in a better place w/ your car
Old May 21, 2016 | 11:12 PM
  #34
2012G37's Avatar
2012G37
Yeah. Thought I'd share..Now to tackle squeaks when I go over speed bumps..Think its coming from the rear sway bar.
Old May 22, 2016 | 09:38 AM
  #35
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
Grease that sucker up....sounds like it's been awhile
Old May 22, 2016 | 06:19 PM
  #36
2012G37's Avatar
2012G37
Ya, been on since Sept. Guess it's time!
Old Jun 3, 2018 | 06:59 PM
  #37
2012G37's Avatar
2012G37
From 85k to 131k and beyond. This G is great with Mods I've done so far. The pads on the BBK were changed out in in late April , I think at 129k. Recently I had to cut into the exhaust line again(leak ) the welding job after driver side RHFC. Muffler shop cut into RHFC, due to rust flang of the stock pipe. Good thing they cut cause a small pipe inside the RHFC had been broken. If i plan for a cat back, i would have to cut again. (All good for now.)
As for my intakes, which were installed several months later; no issues with rain or snow. But, 3 months ago, I have this high pitch noise at high RPMs. Thought it was an exhaust leak, but all leaks were welded last month. I've seen numerous threads on here about it but no fix. I can only assume it's coming from CAI. I saw video of an American car with that issue and i think something was replaced between the intake and MAF....
Chances
Apr 28, 2020 07:52 PM
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
xstarpro
Jan 19, 2016 07:15 PM
cparise
Aug 19, 2015 01:51 PM
Jensen Mathew
Aug 16, 2015 08:06 PM
