New Springs Are Trying to Kill Me
Old Jun 17, 2015 | 12:58 PM
G37X NYC's Avatar
G37X NYC
Originally Posted by JUMBO PALACE
What sway bar did you install? I've seen some people mention doing this but I haven't looked into it at all. Is it an expensive mod?
Hotchkis sway bars, they work well and have good reputation on this forum. Depends what you view as expensive. I think it was like around 500 for parts maybe a little more, and then whatever labor is involved which isn't too much. Your cheapest option would be upgrading that rear sway with the sport sway if you could find one like others have mentioned. But if you don't care about spending the money I deff reccomend hotchkis.
Old Jun 17, 2015 | 01:31 PM
Flakman's Avatar
Flakman
For whatever reason the G37X models have a very small rear sway bar. The RWD journey & sport have much larger diameter tubing so it provides better sway control. The OEM RWD journey sway bars can be found often on this site for about $50 plus shipping give or take. It's a part you can install yourself if you have jack stands.
Hopefully your springs have settled some more and your alignment has changed enough to cause some of that floaty feeling and the fresh alignment will get it driving more like you're used to.
Keep us posted.
Does the xS have a bigger sway than the x (have the sedan if it matters)? I've been looking at the Hellwig rear sway and if the xS sedan has a smaller sway than the Journey and Sport, for $150 it's a cheap mod for the benefit especially to help cure the understeer on the AWD.
Old Jun 18, 2015 | 11:38 AM
JUMBO PALACE's Avatar
JUMBO PALACE
Keep us posted.
I sure hope so. I plan on dropping it of this weekend and I'll bring up how the car feels. Do you (or anyone) think this could be caused by some kind of installation mistake? I know springs are a relatively simple swap but as I mentioned above, I was nervous about this from the beginning. Anyway, thanks for all the support guys. I'll definitely update the thread after my new alignment.
Old Jun 18, 2015 | 07:09 PM
Roadrash666's Avatar
Roadrash666
I was going to stay out of this, but my initial reaction was that maybe your springs are upside down. I'm fairly sure that swifts are progressively wound springs. If they are, the widely spaced coils should be at the bottom and the tightly wound coils should be at the top. My coupe felt planted and stable as soon as I put the Eibachs on it, and even more so after they settled and it was aligned. I may be way off base, but I would think the ride would be pretty wonky if the springs were installed wrong. Hopefully you can get it sorted out, best of luck.
Old Jun 18, 2015 | 07:10 PM
Magowin's Avatar
Magowin
My XS coupe had the small rear sway it was like why bother putting it on. I bought the whole hotchkiss kit for $375 on amazon shipped. If I did it again though I would've just got the rear hotchkiss the front OEM is almost same size as hotchkiss I think it's only 2mm difference.
Old Jun 18, 2015 | 11:15 PM
JUMBO PALACE
A friend of mine had another suggestion that got me thinking. Is it at all possible that the computer is incorrectly sensing slippage? When I get this floaty feeling it feels like the car is hydroplaning and is trying to correct itself. I'm probably wrong but it was an interesting thought none the less.
Old Jun 18, 2015 | 11:23 PM
G37X NYC's Avatar
G37X NYC
Doubt it, if it was sensing slippage you would get the blinking slip light.
Old Jun 18, 2015 | 11:42 PM
That would only occur if you changed to a new set of staggered tires where the front to rear diameter variance is too great. If you're still on stock size tires all around you shouldn't have any slippage issues with normal driving (assuming your tires aren't overly worn) if you're driving very aggressive then maybe, depending on tire quality.
Old Jun 23, 2015 | 05:37 PM
yoshih's Avatar
yoshih
I dont know if this issue was solved but maybe you might want to take a look at your rear toe.
Only because the number is positive. toeing the rear in will help settle the rear down.
Old Jun 24, 2015 | 11:46 PM
JUMBO PALACE
Well, turns out my tires were pretty bald so I got a new set off of Tirerack and those go on tomorrow. Should be all good after that I hope! Went with the Continental Extreme Contact all season tires. I'll probably do wheels and larger tires down the line but this had to get done asap.
Old Jun 25, 2015 | 12:41 AM
Better change the thread title to "Old balding tires trying to kill me"
Glad you're getting things sorted out
Old Jun 25, 2015 | 01:28 AM
Flakman's Avatar
Flakman
Old Jun 25, 2015 | 10:47 AM
chilibowl's Avatar
chilibowl
Turns out?
How do bald tires ....just "turn out" ?
LOL
Old Jun 25, 2015 | 01:30 PM
  #29
JUMBO PALACE
Yeah yeah I deserve all of the facepalms haha. First car I've really started paying attention to and modding so the obvious sometimes escapes me in my anxiety that I screwed something up. I'll chalk it up as a learning experience and pay closer attention
Old Jun 25, 2015 | 02:00 PM
  #30
Have you already got the tires installed, and if so are you now happy w/ the drive?
I think all of us have had things we've neglected or just weren't aware of paying much attention to. Such is life......
