Bagged g37 vert
Old Jun 1, 2015 | 03:19 PM
G37_Serg's Avatar
G37_Serg
Bagged g37 vert
I really want to bag my IPL convertible
But I have no idea where to put the tank any ideas ? I seen one guy located his under the car I really don't want to do that
Old Jul 17, 2015 | 10:51 PM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
Two 3 gallon tanks in the rear bumper, but I'd not recommend that. If you et rear ended it would suck.
Under the rear section where the muffler is, is the other location. Muffle delete needed, and likely new cat back to clear the tank. You'd have to do some measuring. That would be my plan.
Otherwise a custom tank to fit where that flap is by the inside of the trunk. Slim tank, for that small space.
Old Jul 17, 2015 | 10:53 PM
beachbum718's Avatar
beachbum718
Pancake tank. Right where spare goes.
Old Jul 18, 2015 | 12:48 AM
cereal2k's Avatar
cereal2k
Some verts don't have a spare. Pancake won't fit on those I think, but someone's gotta try it for sure and see. The roof folds on top of a maybe 4 inch height pocket area. Anything in the way will break the back window when it folds in.
But with a spare tire area (I've yet to see one on a vert), the pancake should work.
Old Jul 18, 2015 | 01:00 PM
Coy1231's Avatar
Coy1231
I've entertained the idea of using the spare tire wheel well too but wasn't comfortable with the pancake tank due to how close the glass is....I've also considered the use of 1" SS tubing bent/shaped (over-under style) in the shape of the spare tire wheel well side walls. This would leave the center open for pump, connections, etc...My calcs show it would take 28.3 ft of tubing to be equivilant to a 5 gallon tank. Like I mentioned above just toying with the idea but def think it would work.
Old Sep 23, 2015 | 03:13 AM
1RAWG's Avatar
1RAWG
Not sure if you are still considering it, but I put my tanks inside the bumper and mounted above the crash reinforcement brace. If you don't like the idea, my suggestion would be the pancake tank option. I'm not experienced on that setup, as theoretically it should work fine, but I have proof that having it inside the bumper works too.
Old Oct 1, 2015 | 04:40 PM
cereal2k's Avatar
cereal2k
Hey 1rawg, show that off man
Insprire the rest of us to go bagged.
JRW370
Buying & Leasing
Apr 8, 2019 09:24 PM
meme405
The FX-Spot
Feb 18, 2019 10:00 PM
rdog
Nov 26, 2015 12:50 AM
teonguyen
Aug 24, 2015 01:56 PM
