Lowering my G37x
Old May 10, 2015 | 12:34 PM
Dillybar12's Avatar
Dillybar12
Lowering my G37x
Hey guys,
Finally got some extra money laying around to where I can order springs for my AWD.
For you car gurus out there, is this drop too much for an AWD?
Front: 1.9
Rear: 1.6
http://m.autoanything.com/suspension-systems/61A2549A0A0.aspx
Thanks.
Old May 10, 2015 | 12:48 PM
Originally Posted by Dillybar12
Hey guys,
Eibach Pro Kit Lowering Springs - 238+ Reviews on Eibach Lowering Springs
Thanks.
Eibach would be considered a mild drop, might also consider the new AWD coupe springs from Swift, and here's ano0ther option if you want to keep your camber in spec without camber kits (although this is a RWD coupe so your X coupe may be a bit higher)
https://www.myg37.com/forums/brakes-...or-your-g.html
Old May 10, 2015 | 01:16 PM
Dillybar12's Avatar
Dillybar12
I feel as if the 1.9 and 1.6 is way too much now.... He only dropped .75 max
Old May 10, 2015 | 02:11 PM
Might consider the Tanabe springs, then if the drop is too low you could go w/ the link I posted to modify the set.
Old May 10, 2015 | 05:41 PM
Dillybar12's Avatar
Dillybar12
I'm looking for a safe drop that won't mess up my AWD system. If 1.9 and 1.6 won't mess it up, I'm down.
Old May 10, 2015 | 09:51 PM
As far as being safe, depends what you have to deal with on your daily drives, what may be "mild" to me may be rather severe in your case
You should get at least a rear camber kit w/ that setup.
G's
Nov 5, 2023 12:01 PM
G37xhibeet
Nov 15, 2016 09:29 AM
derekjl
Oct 2, 2015 05:05 PM
DenserAsteroid
Aug 30, 2015 11:11 PM
