Changed driving dynamics lowered on Swift Springs: G37x
I have the Swifts/Koni's and Hotchki's on mine (not an X). The Hotchki's are at the middle setting front and rear, but the car doesn't feel as solid nor does it corner as well I thought it would. It could be the 75 pound W7 speaker/box in the trunk lol. Anyway, I was considering changing the rear setting to the most stiff, but you have me second guessing that now...
3/4 of a full turn from the softest setting. I wanted it to feel as close to stock under normal driving (which it does) but still feel planted when turning (which it does).
I think it's just a heavy car that I need to get used to. My last car was a 2004 Accord Coupe which is about 400 pounds lighter, and felt it.
VQ-vic: Good call man. I haven't done the alignment yet; I was going to get it done this weekend since the springs have now had time to settle. I guess the sliding could be caused by the increased negative camber. Maybe I should have gotten that done before posting...
Doesn't a little negative camber help for handling?
Full disclosure, I knew one of the techs there came highly recommended so I make certain that I always get on his hook sheet but it's good to have that option.
I got the alignment done and now have -2 degrees camber all around, but everything else is in spec. Car does feel better compared to before.
I mentioned it in an earlier response- I have newer Hankook Ventus V12s, but they weren't the problem.
Thanks for everyone's comments and suggestions!
Glad things are going in the positive direction. -2' camber is right about the same I run on my car. It's prob the most aggressive one can get on a daily driver. With your mods alone, at their softest settings, you already have a substantial improvement over stock on a already good handling vehicle.
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
SLEV3N
General Tech Questions
Oct 17, 2015 05:58 PM
