what is the difference between RWD and AWD coupe eibach springs
I have x coupe and recently bought a used eibach pro kit springs(#6394.140)
and noticed dust boots and bump stops are missing.
so I was searching for those parts and found that there is no difference between the two springs #6394.140(for AWD coupe) and #6388.140(for RWD coupe) since those two pro kits has exact same springs(part numbers are same), and only difference between the two pro kits are #6394.140 has dust boots and bump stops in the package while #6388.140 has springs only.
Anyone here who has AWD coupe and installed the eibach springs with oe dust boots and bump stops?
here is the "instruction" for those two pro kits. you can see they use exact same springs.
http://www.catalograck.com/imgvd/EIB/d2753.pdf
http://www.catalograck.com/imgvd/EIB/d2803.pdf
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
