Steering wheel off center
Old Jul 12, 2014 | 12:48 AM
MP87's Avatar
MP87
Hi all,
I have a peculiar situation. My car does not pull to one side or the other when driving but the wheel is off center when I drive the car straight. Specifically, the wheel is a few rotated a few degrees counter clockwise. Its not totally bad but its noticeable enough to make the car look cheap.
My question is, how difficult would it be to correct this? Luckily my car is under warranty but I wanted to check with the community first since I am not sure if this is one of those things where more harm can be done in trying to fix it.
Any input would be appreciated, thanks!
Old Jul 12, 2014 | 01:30 AM
chris5o4's Avatar
chris5o4
an alignment should fix it
Old Jul 12, 2014 | 02:16 AM
RedEyeZ88's Avatar
RedEyeZ88
The same exact thing happens to me, and I did get it aligned at the dealership. Not sure how else to fix it.
Old Jul 12, 2014 | 02:48 AM
Gio37's Avatar
Gio37
Happened to my G when I installed the Eibach springs & SPC camber kits.....took it to have it aligned and it was back to normal.
g/l
Old Jul 12, 2014 | 07:25 PM
cruzmisl's Avatar
cruzmisl
Same thing here. The dealership just isn't that great at getting it set up correctly when doing an alignment. I've taken it back 3 times, then gave up.
I might try a different independent shop next.
Funny thing is, before my alignment, everything was perfect. But after doing an alignment after getting new tires (because that's what we're supposed to do?), I have this problem.
I should have left it alone.
Old Jul 13, 2014 | 11:22 PM
MP87's Avatar
MP87
Thanks guys, the off center steering wheel really bugs me. I think I am going to take it into the dealer to get it aligned then.
Old Jul 20, 2014 | 12:46 AM
RedEyeZ88's Avatar
RedEyeZ88
@cruzmisl, same thing happened to me. I got new tires and since you "need" to get alignment done aftewards I did, and then for some reason that means turn the steering wheel at a slant to go straight.
Old Jul 20, 2014 | 02:33 AM
kRAM's Avatar
kRAM
Originally Posted by cruzmisl
Same thing here. The dealership just isn't that great at getting it set up correctly when doing an alignment. I've taken it back 3 times, then gave up. I might try a different independent shop next. Funny thing is, before my alignment, everything was perfect. But after doing an alignment after getting new tires (because that's what we're supposed to do?), I have this problem. I should have left it alone.
Had the same issue with the dealership when they replaced my differential bushing under warranty. They tried to do the alignment but messed up toe and camber and said it was the best they could do. Took it to a shop that only do alignments and got it exactly where I wanted within 0.01 of what I asked for.
Old Jul 20, 2014 | 02:41 PM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
+1 on the alignment.. Should be a quick fix
Old Jul 23, 2014 | 02:52 PM
infinitiman96's Avatar
infinitiman96
Sounds like your toe is out of adjustment. Easily remedied with an alignment.
Old Jul 23, 2014 | 03:07 PM
Tommy Gunz PSIU's Avatar
Tommy Gunz PSIU
So I'm surprised noone has asked this yet... Has the steering wheel been like this since you got the car?
If it has, then there is a chance that someone (maybe the dealership you bought it at) took the steering wheel off at some point for some reason. Do the 2013s have the same stock bezel as the 08s, or did they fix that material on the later models?
When you put the steering wheel back on, there are a ton of splines that you slip the wheel back onto. If they replaced this at an "off" angle, then that's your problem right there...
Old Jul 23, 2014 | 06:11 PM
Need 4 Speed's Avatar
Need 4 Speed
+1 with the alignment that usually fixed all of my off centered steering wheels.
Ryne
Jan 18, 2016 05:39 PM
joeposter
Sep 8, 2015 04:36 PM
xpcgamer
Sep 5, 2015 09:28 AM
mauiwowie
Aug 16, 2015 06:01 PM
