Sway-bars - changing Journey to Sport OEM model, on a budget
Old Jun 26, 2014 | 07:31 PM
codeflux's Avatar
codeflux
20 Year Member
Question Sway-bars - changing Journey to Sport OEM model, on a budget
I've been trying to find definitive info, and can't. Yes, I've searched.
I have '11 G37 Journey sedan non-sport RWD. As you guys know, the sway bars aren't too stiff. So, I am looking at trading up to sport OEM sways, as a budget alternative to getting Hotchkis, which would admittedly be a better albeit more expensive choice.
1. Do G37 coupe sways fit G37 sedans? - all info I was able to find points to YES, but I'd like confirmation.
2. Are OEM sport sways more stiff than OEM non-sport? - YES, but what is the stiffness difference?
3. Are OEM sport end links different from OEM non-sport end-links? - anyone knows?
Old Jun 26, 2014 | 07:34 PM
codeflux's Avatar
codeflux
20 Year Member
According to this thead:
https://www.myg37.com/forums/brakes-...lications.html
Hotchkis stiffness specs are:
Front Sway Bar 35mm (Ø1-3/8") Hollow
+230% Stiffer than Stock G37
+205% Stiffer than stock G37S
+230% Stiffer than stock G37S
Rear Sway Bar 27mm (Ø1.063") Hollow 3 Way Adjustable
+120, 175, 250% Stiffer than Stock G37,
+5, 30, 65% Stiffer than stock G37S
+50, 90, 145% Stiffer than stock G35S
If I'm reading this right, the front OEM sport vs non-sport have 25% stiffness diff, and rear OEM sport vs non-sport - 115% stiffness diff.
But another set of eyes would be nice.
Old Jun 26, 2014 | 08:51 PM
malady's Avatar
malady
not sure If this helps but found some stiffness % in this thread: https://www.myg37.com/forums/private...sway-bars.html
Old Jun 26, 2014 | 09:18 PM
codeflux's Avatar
codeflux
20 Year Member
OK, so he says
Front:
~25% Stiffer than Stock G37
Rear:
~150% Stiffer than Stock G37
But that info is based on Hotchkis website too. And the rear number sounds a bit off.
Old Jun 26, 2014 | 09:32 PM
I got Rochesters' Sport sways from his Sedan and put them on my Journey Sedan a while back. No difference in outside diameter, and while I didn't weight them they feel very similar in weight. Combined w/ my coilovers I notice a slight change in higher speed cornering but not enough that I would recommend getting them. If you're going to upgrade sways I'd go aftermarket.
Old Jun 26, 2014 | 09:40 PM
codeflux's Avatar
codeflux
20 Year Member
That's what I'm beginning to realize as well...
Old Jun 27, 2014 | 02:24 PM
DEPluma's Avatar
DEPluma
CodeFlux.......if this helps....I have a set of OEM 37S sway bars from my 08. I replaced them with Eibachs on front and rear. I use the car for autocross and I can tell a difference in the OEM vs Eibachs. If you are interested in them...PM me. Otherwise, good luck on the search, this is always a hard thing, at least it was for me. I just dove into the Eibachs and don't regret it at this time.
Old Jun 27, 2014 | 09:30 PM
Motoboat's Avatar
Motoboat
You could always try an AWD front sway, It is larger than the sport OEM and just a few mm smaller than the hotchkiss, and then pair it with the sport rear sway which is the largest of the OEM rear sways. These might pair up well on a budget. (Actually it's what I use along with the cusco ftsb)
This is assuming the research I did on this last summer when I was doing the same thing is correct, so if anyone knows different, please correct me.
Thedbarz
33
Feb 9, 2016 12:05 AM
Ricio1991
Aug 27, 2015 10:17 AM
KAHBOOM
Aug 25, 2015 11:05 AM
Digilog
Aug 17, 2015 03:54 PM
RoyalG37
Aug 11, 2015 12:21 PM
