G37 original stock brake life
Old 05-16-2014, 11:37 AM
Cbyl5
Cbyl5's Avatar
Getting oil change at a Nissan dealership and was told rear brakes need to be replaced and front brakes are nearing replacement condition. Car is 2011 model with less than 27K miles. Is this typical brake wear or am I being taken for a ride?
Old 05-16-2014, 12:10 PM
Carfreak70852
Carfreak70852's Avatar
Pad wear is really dependent on the driver. Is it possible, yes. But most of the time (from my experience) the front pads wear quicker than rear pads (as the calipers are bigger and more braking force is sent to the front). 27K miles does not sound too far off for pads if you are a mildly aggressive with the brakes. Ask to see the old part and verify with your own eyes that they were in fact needing replacement. That is what I do.
Old 05-16-2014, 01:33 PM
BlackGSedaN1027
BlackGSedaN1027's Avatar
In my personal experience, I have a 2009 G37S and still have the original pads/discs with 64k miles on them (mostly highway). However, I will need to replace the front pads and probably the discs very soon.
Old 05-16-2014, 03:56 PM
Fentress24
Fentress24's Avatar
I have 63k on my stock brake pads. They will need to be replaced this summer probably.
Old 05-16-2014, 04:15 PM
Racerman
Racerman's Avatar
I have a 2009 S model with about 60,000 and the brakes are ready to be replaced. The rears will wear out faster if you engage the traction control a lot. The traction control applies rear brake to stop tire spin and if you are a spirited driver you can wear the rear out faster than the front (used to do that on my G35)
warped ideas (05-21-2014)
Old 05-16-2014, 04:32 PM
pricojorge
pricojorge's Avatar
I was on stock pads and rotors until about 75k miles but I kinda milked it and I also do alot of highway travel, in my experience the rears wore down faster than the front
Old 05-16-2014, 04:59 PM
sprix
sprix's Avatar
As a few other people have stated... brake wear and life of pads is largely dependent upon driver habit and style.
If they say the pads need to be replaced and you are skeptical, you can ask them to show you the pads and prove it. It isn't difficult for them to do a show and tell instead of just telling you that the pads are bad.
Old 05-16-2014, 09:55 PM
Adam West
Adam West's Avatar
I replaced my rear pads around 30k and they were getting down there, but again it depends on driving style and how hard you are braking, engaging traction/dynamic control, etc.
Old 05-16-2014, 09:59 PM
kaoticdemize
kaoticdemize's Avatar
2012 G37 S, replaced rotors at 12k miles haha
Old 05-16-2014, 11:11 PM
UCLAG37
UCLAG37's Avatar
Just did my first front brake job after 5 and a half years on original pads and 33K miles. I still had 40% left. I didn't like the longer pedal travel feeling so I swapped out the pads. About 50% city/highway. I'm usually swapping out front pads at 35K to 40K on other cars but usually down close to the indicator. By the way, this was one the easiest brake jobs I've ever done.
Old 05-16-2014, 11:53 PM
]\[ /-\ ]\/['s Avatar
i rarely brake hard at all.
i did the front pads at about 60k and still had about 40-50% left. they were squeaking so i figured I'd change them.
I'm at 89k miles now but still on original pads in the rear.
Old 05-21-2014, 12:36 PM
pmh6778
pmh6778's Avatar
How about the rotors? What's the life expectancy on those? Normally at the same time as the pads?
Old 05-21-2014, 09:40 PM
sprix
sprix's Avatar
There's a reason brakes and tires are never covered under any kind of warranty... it is impossible to predict how long wear and tear components like these will last. Depending on your driving style, driving conditions, and price of tea in China, the life expectancy can vary fairly wildly.
What's the phrase I'm looking for... Ahh. "Your mileage may vary".
*ICE* (03-13-2017)
Old 05-22-2014, 09:48 AM
Pnrymmf
Pnrymmf's Avatar
Have any of you guys use the carbon ceramic pads? I used them on my g35 and really liked them. They produce less dust, they were much less noisy than the others until towards the time to replace them and they are way more friendly on your rotors. I got them from Stillen. I tried to get the dealer to put them on my wife's EX but they made a bunch of excuses, she doesnt keep teh car as clean as i do and since it is not driven much i figured just go with it. Just curious on the G37 and with the bigger brakes what experience you guys have had.
Old 05-23-2014, 12:24 PM
cruzmisl
cruzmisl's Avatar
45k on my stock sport pads. Reputable shop said there's 30-35% life left on them, easy.
Quick Reply: G37 original stock brake life
