Rear camber control arms for 2009 G37 convert?
Old Feb 24, 2016 | 02:29 PM
  #31
Pnrymmf's Avatar
Pnrymmf
Originally Posted by stevelam
no im on stock height but i still get the bad tire wear.. i belive it has to do with all the extra weight. my friend has a coupe and he has th einner tire wear but not quite as bad.. as for doing the tire swap thats exactly what I plan to do as well to get a lil more treadlife. Im currently gone back to school on the midst of a career change so anything to save a bit of coin is definitly a big helper. I really wanna lower my car but in all honesty Im waiting for cereal to install the bc coils to get an honest review from him on them.. then ill have more ***** to pull the trigger.. plus im afraid lowering will give me clearance issues with the ARK Grip...
My IPL vert is on stock springs and height and I get the inner rear wear as well. the last time I replaced the tires they said an adjustment was done but I do the same thing every so often. take the wheels off and remount to get more wear time. I was told weight is what causes it too.
Old Mar 13, 2019 | 08:16 PM
  #32
teahead's Avatar
teahead
https://meganracing.com/suspension/t...s-ns-0420.html
As a potential remedy
Old Mar 13, 2019 | 08:30 PM
  #33
Originally Posted by teahead
Have you contacted Megan Racing to confirm vert applications? Would be nice for you guys to have more than just an elongated camber bolt slot to adjust camber.
Old Mar 13, 2019 | 08:44 PM
  #34
teahead's Avatar
teahead
I chatted with some tech online and he said yes.
Old Mar 14, 2019 | 08:51 AM
  #35
Nice! I know the lower arm is completely different on the verts but didn't pay attention to the upper, if you give this a shot be sure to keep us informed, as this is a big deal for you vert folks!
Old Mar 27, 2020 | 02:57 PM
  #36
1lowg37's Avatar
1lowg37
Vert camber arms
This is my solution
Old Mar 27, 2020 | 03:47 PM
  #37
BULL's Avatar
BULL
Moderador
Looks like the issue is that the convertibles have the spring in the shock instead of the arm like the coupe and sedan but the shock bolts to the arm instead of the knuckle like newer infinities.
Old Jul 3, 2020 | 02:33 PM
  #38
Rita Crenshaw's Avatar
Rita Crenshaw
Love the look of your vert! I have decided to keep my vert and fix it up/trick it out (so my sons will have a reason to hang out with me, lol). It is a 2010 base G37 Convertible. I replace rear tires twice a year due to inner tire wear. I would like to purchase a set of the adjustable rear camber arms that are modified like the picture above shows. They are the only ones I have seen that look like they will fit on my car! Who do I contact to have some made for my vert?
Old Jul 3, 2020 | 05:44 PM
  #39
1lowg37's Avatar
1lowg37
I made them myself. You just need to get the correct style camber arm kit to make it work.
Old Sep 22, 2020 | 07:13 PM
  #40
Tucsontripleb's Avatar
Tucsontripleb
Question....
Originally Posted by 1lowg37
This is my solution
Nice solution!
What brand camber bar did you use?
Do you have a brand/part # for the shock mount?
Do you have any pictures under the car with these installed?
Old Sep 22, 2020 | 09:54 PM
  #41
1lowg37's Avatar
1lowg37
Originally Posted by Tucsontripleb
Nice solution!
These are the camber arms I used. I made the shock mounts myself and used the nut lug from the stock one so i could use the original bolt. I will try to take some pics under the car and add them.
Old Sep 23, 2020 | 11:34 PM
  #42
Tucsontripleb
Awesome! Thanks for the reply. Another person on this forum welded the shock mounts to the side of the camber arm. Don't like the lateral forces on that set up, but that led me to this solution in my head. Thanks for leading the way on this.
Pics of install under car would be great if you can, but this is good enough to duplicate as is.
Old Oct 23, 2022 | 10:10 PM
  #43
Looking4g37's Avatar
Looking4g37
is anyone on this forum able to custom make these for my 11 g37 vert?
morning is there another solution guys are using more recent than this?
move been searching and a couple posts have links to different products but the links don’t work
This is my solution
Old Feb 6, 2023 | 08:53 AM
  #44
dsmoove91's Avatar
dsmoove91
2010 Infiniti G37 vert
Alright I got a partner that can wield and Imma try it. Damn, I wanna know if it worked out. Guess I will find out soon enough.
Jordan Ramon
Apr 5, 2023 08:55 AM
saywat?
Feb 3, 2020 09:15 PM
grocerylist
Jul 10, 2019 10:01 AM
Dtyler
Nov 13, 2018 08:25 PM
celwin
Sep 30, 2016 01:39 PM
