How Low is this G?
Old Mar 30, 2014 | 07:29 PM
Quenblue4's Avatar
Quenblue4
How Low is this G?
And can you achieve this height with Stance coil-overs or swift springs?
Old Mar 30, 2014 | 08:51 PM
Sunny G's Avatar
Sunny G
you can get that drop with the coils. the swift springs give a very mild drop
Old Mar 30, 2014 | 09:14 PM
warped ideas's Avatar
warped ideas
A quarter past stripped
+1^^^
Those rims look like 22" as well, so that could be giving the car a more "dropped" look. Coils will get you lower, while Swift and Eibach do give a more moderate drop.
Old Mar 30, 2014 | 09:30 PM
You may get a drop similar to that w/ H&R springs and maybe Tein S-techs, and like mentioned above, for sure w/ just about any coilover.
Old Mar 31, 2014 | 08:21 AM
Quenblue4's Avatar
Quenblue4
But, how low is this drop? Numbers...
Old Mar 31, 2014 | 08:59 AM
If those are 20s then it's about the same as my zero gap drop so about 26" give or take from the ground to the highest fender point.
Old Mar 31, 2014 | 09:59 AM
Quenblue4's Avatar
Quenblue4
What are you dropped on?
Old Mar 31, 2014 | 10:08 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
I've got BC Coilovers, blnewt has Megan Coilovers
Old Apr 1, 2014 | 08:30 AM
Quenblue4's Avatar
Quenblue4
Will this drop clear speed bumps and other road hazards pretty good?
Old Apr 1, 2014 | 08:48 AM
Once you get used to how to navigate steep angled drives and don't mind annoying those behind you when you have to crawl over speed bumps it isn't too bad. One reason I got the coilovers is I was TOO low on my B&G springs, I was 25.75" at the front and that was too low for me, made drives more stressful than I wanted. The 1/2" higher that I'm set on my coils made a huge difference. If you're on a stock setup w/ suspension, wheels & tires be prepared for a dramatic difference in ride comfort if you go from 18" wheels to 20s and the narrower sidewall tires combined w/ firmer springs or coils. I like the firm ride and "connection" to the road, but it's something you need to be aware of.
Brad
Old Apr 1, 2014 | 09:21 AM
dkmesa350z's Avatar
dkmesa350z
Originally Posted by warped ideas
+1^^^
Those definitely are not 22s. That G has 20s.
Old Apr 1, 2014 | 09:25 AM
Quenblue4's Avatar
Quenblue4
I was thinking about Stance, what's the max height? I don't want to go too low. Probably just the height in this pic or a little higher.
Old Apr 1, 2014 | 11:07 AM
Stance are a good choice, I'd contact Need4Speed and mention myg37.com here's their site, the owner has these coils on his G and should be able to give you specifics regarding height. They should adjust higher than that pic for sure.
Welcome | Need 4 Speed Motorsports Inc.
Old Apr 1, 2014 | 11:18 AM
Diego@Vossen's Avatar
Diego@Vossen
He was on KWV1 Coilovers. Drop was about 2 inches all around. Looked great!
Old Apr 27, 2014 | 07:05 PM
erinmac's Avatar
erinmac
So do the coilovers help with limiting the upward travel that's giving me the slight rub when I hit the large dips? I know they are stiff, just hoping the rigidity might be tighter or more adjustable than springs would offer.
04G35NYC
Jul 19, 2016 01:42 AM
faze2988
Oct 7, 2015 12:05 AM
parkern
Oct 5, 2015 12:12 PM
Bennyjoel
Sep 30, 2015 11:56 PM
Detailed Image
Lighting/Cleaning Products
Sep 28, 2015 07:02 AM
