I have a 2010 G37xS and I recently purchased the Infiniti BBK. I plan on using Goodridge Stainless Steel brake lines. Do I purchase the lines made for the AWD or the Sport.
Thanks
Gabe
You should go AWD and replace with 17mm Benjo bolts (default came with 20.3mm, that will leak) if you use Akebono caliper or AP caliper.
As that's custom order, it should be at minimum charge.
