No Brakes Twice
Old Jan 23, 2014 | 09:29 AM
shanezam203's Avatar
shanezam203
No Brakes Twice
I have a 2008 Infiniti g37 coupe with 111,000 miles and twice now in Stop and Go traffic my brake pedal has gotten STIFF and the car did NOT stop. I was lucky eventually brakes came back but twice now the car's brake pedal felt similar to it does when the car is OFF and you pump the brakes, soon it locks up and does not go in.
Any idea what it could have been, brakes are fine now and stopping just fine @ 6-mph and in stop and go both... thank you,
Shane
Old Jan 23, 2014 | 10:36 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Not sure what exactly is causing the problem, but with high mileage cars like that, you might want to check the entire system. Flush/change brake fluid, check rotor surfaces, check pads, check your brake lines, too.
Old Jan 23, 2014 | 10:42 AM
BLamb's Avatar
BLamb
My guess is a bad brake booster. But as said above check everything and flush the fluids.
Old Jan 23, 2014 | 12:57 PM
rmfnla's Avatar
rmfnla
That was my first thought as well; sounds like he lost vacuum...
Old Jan 23, 2014 | 09:18 PM
monytx's Avatar
monytx
You might want to check out your master cylinder as well..
Kojack
Oct 9, 2015 05:53 PM
Mattimus
Oct 4, 2015 01:33 PM
Bennyjoel
Sep 30, 2015 11:56 PM
Soccer4555
Sep 30, 2015 05:31 PM
VIVID
Sep 27, 2015 09:45 AM
