KWv1 Rear Spring Perches... Height Difference?
Is it ok/normal for the height-adjustment collars on the rear spring perches to be set at different heights? The passenger-side collar had to be threaded farther down the perch than the driver-side collar to achieve an even ride height at the desired height. Everything is installed correctly as far as I can tell. I had my alignment shop check the installation as well and was told everything is fine. The tech said the setup is fine and safe, but I was just wondering about the difference in height. Should I just chalk it up to varying production tolerances in the parts and not worry about it? Thanks.
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
