SPL front endlink nuts backing out?
Old Aug 15, 2013 | 01:52 AM
Hapa DC5's Avatar
Hapa DC5
I have had my SPL front endlinks on for the past week or so. Very well built, quality feeling product.
However, when I went to recheck my install it seemed as though the nuts on the sway bar end link is backing out a bit?
I torqued them to SPL's spec (85 ft. lbs.) on the initial install. After a week of driving I was noticing a faint clunk or pop and drove my car up on an alignment rack at my buddy's shop. I noticed some play on the end link and it took a full turn or two before it went back to 85 ft. lbs. My sway bars are eibachs BTW and the front is set to the softest setting.
Anyone else experience this issue? Should I use lock tite?
I'll recheck again in the following week.
Thanks all.
Old Aug 16, 2013 | 01:30 AM
Emillion45's Avatar
Emillion45
Did you use any Loctite?
Edit:
Use Blue or Red Loctite. I went with blue and have had 0 issues.
Last edited by Emillion45; Aug 16, 2013 at 01:34 AM. Reason: Didn't read the "should I use loctite" portion of the OP's issue.
Old Aug 20, 2013 | 12:40 AM
Hapa DC5's Avatar
Hapa DC5
Thanks I'll have to do that when I recheck again.
Old Oct 19, 2013 | 04:33 AM
TheGspot37s's Avatar
TheGspot37s
I've had the same issue w my rears. I'll have to try the loctite
GrayG37
Feb 10, 2022 11:52 AM
Thedbarz
33
Feb 9, 2016 12:05 AM
gcruzjr78
Aug 18, 2015 10:15 AM
xxg00w0
Aug 14, 2015 07:15 PM
