Brake pad part numbers
I am finding too many options....I need the part numbers for 08 g37S coupe brake pads! Akebono or stoptech please. Ive spent an hour searching and there are way too many options and part numbers showing up. I am just looking for replacement pads for the S model.
Front 30913460 More Information for CENTRIC 30913460
Rear 30913470 More Information for CENTRIC 30913470
Can anyone chime in for a G37x (2010)?
I've been on both TireRack and Rockauto and I'm finding different part numbers with the same descriptions.
These are what I'm looking at.
Front CENTRIC 10508880
Rear CENTRIC 10509051
Thanks,
Thanks,
Gio37 (02-10-2014)
Thanks,
Thanks,
Here's all the X brakes which are easiest to ID from the front brake rotor diameter
X and XS sedan 320mm front rotors
X Coupe 330mm front rotors
XS Coupe 355mm front rotors (and the big pretty Akebono Calipers)
First, thanks for all the help! I was able to order, and for the most part, get everything replaced today. The fronts where easy but I couldn't get the rear rotors off because I didn't have a 19mm box wrench with me.
The best...ok worst part of the day was when I was all done, finished my test drive, and got back to realize that I left the key to my wheel locks on one of the wheels. I'm guessing that the dealership won't be able to "cut" me a new key I'll probably need to get all four replaced.
G37xS Sedan Part Numbers:
CENTRIC 10509051 (Rear Pads)
CENTRIC 10508880 (Front Pads)
CENTRIC 12042088 (Rear Rotor) (307mm)
CENTRIC 12042080 (Front Rotor) (320mm)
photocat
09-03-2015 01:46 PM
KZK
Canada
09-02-2015 05:30 AM
