Suspension up grade. Koni + H&R or KW
Old Aug 4, 2013 | 01:18 PM
Templos's Avatar
Templos
I've Belén reading a lot regarding susp up grades.
Would like to enhance drive while lowering an inch or so.
Since my G is DD and no track intention, 7AT with many road trips, my final options are:
Koni Sport kit with H&R sport springs or. KW V1 coils
In México both cost about the same. But know koni kit is cheaper in the states.
Would like to have some reviews from current / past users of both set ups.
I know one set adjust height, while the other damp. But looking to learn from other sedan users which they found best option.
Read some where here trat konis actually "increase height". Is that right.?
Thanks in advanced
Old Aug 4, 2013 | 02:24 PM
MACS's Avatar
MACS
I have the KW variant 3 on my daily driver. I've been absolutely satisfied with the upgrade.
Old Aug 4, 2013 | 02:31 PM
Skyline6mt's Avatar
Skyline6mt
The koni won't raise the car in the thread your thinking of the guy had installed them incorrectly.
IMO if you want adjustability go with KW if you want to set and forget and not have to think about maintenance go twitch the konis and good springs.
Also H&R will likely be lower than an inch drop I'd look into swift springs if you not looking at going too low.
Old Aug 4, 2013 | 03:28 PM
I think this is the setup the OP is talking about since it's a very new product (or at least a very new "alliance" between the 2 companies), and it does look like it'll drop about 1.25"-1.5" (30-35mm F, 25-30mm R)
which would be a good drop for a DD.
Only problem is I haven't found a US source for the kit, just UK sites thus far
Koni Sport Suspension Kit (with H&R Springs) for Infiniti - larkspeed.com
Old Aug 4, 2013 | 03:52 PM
mpegripper's Avatar
mpegripper
that says coupe?
4DRZ
Nov 7, 2015 08:32 PM
Sleepstupid
Oct 15, 2015 11:16 AM
Soccer4555
Sep 30, 2015 05:31 PM
Wreckreation
Sep 21, 2015 06:27 PM
m3clubracer
Sep 20, 2015 09:20 PM
