G37 vert brake pads ceramic and metalic from dealer
Old Jun 26, 2013 | 10:51 PM
rdog's Avatar
rdog
I bought a 2011 vert from an Infinity dealer in Naperville, IL a month ago and the braking seems to grind. I have a 2004 Pontiac GP with all ceramic pads and brakes with no grinding at all. I get light brown dust on the rear wheels (ceramic?) and a lot of black dust on the front wheels (metalic?). Is there an issue with mixing brake pad types on my car?
Old Jun 30, 2013 | 06:46 PM
bythabay's Avatar
bythabay
20 Year Member
The pads that show the higher dust, if they are infiniti oem pads, are the high performance pads that are very aggressive with respect to wear of both the pad and rotor. You need to make sure if you are using such a pad that you do so with a set of high carbon rotors, to avoid excessive thickness variation that will lead of vibration/pulsation.
Old Jul 2, 2013 | 11:51 AM
rdog's Avatar
rdog
Thank you for the reply and the information. Very helpful.
JRW370
Buying & Leasing
Apr 8, 2019 09:24 PM
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
zero260
Aug 12, 2015 10:02 AM
Peter Reynolds
Aug 6, 2015 07:53 PM
