Rear Akebono is enough for 700hp?
Old May 23, 2013 | 05:25 PM
martalex's Avatar
martalex
Hello
I'm waiting for my TT GTM Power package and I would like to be 100% prepared for it. I have already 380mm drilled front rotors with 8 spot calipers but now I need to upgrade rear brakes. I was told that Akebono rear 2 spot brakes with 350mm rotors will be enough for my future car (700hp).
What do you think? Will I be satisfied with it?
Or it's better to take the same 380mm rotors with 6 spot calipers?
Thanks in advance for a advices
Old May 23, 2013 | 05:30 PM
Modme's Avatar
Modme
Brakes upgrade has little to do with how much power youre making. It's more about what do you plan to do with your car. For spirited driving, the stock Akebonos are sufficient. If you're tracking the car, then you'll probably want to upgrade it.
Old May 23, 2013 | 06:00 PM
martalex's Avatar
martalex
Thanks... You saved me 1000$
Old May 23, 2013 | 06:06 PM
Rad_Slinger's Avatar
Rad_Slinger
As Modme said, the akebono calipers are sufficient for spirited driving.
Think of it this way...ya, you're waiting on our TT and you say you'll be pushing 700hp, but how often are you going to be using all that HP? How often will you be going in excess if 125mph? And how often are you gonna to be going that fast and need to stop quickly?
I suppose you can get a Stoptech BBK to be safe, but I think you'll be fine with the akebono calipers and a good set of pads.
BTW, something you may want to think about....maybe invest in some SS brake lines and some high temp brake fluid, that'll help with fade.
Old May 23, 2013 | 06:10 PM
martalex's Avatar
martalex
thank you very much... it was very usefull
Old May 23, 2013 | 11:05 PM
As was stated, if you aren't tracking the car, OEM brakes are plenty sufficient. Track use puts a lot more load on the braking system - constant use for prolonged periods that build up heat in the system quickly. Over and over.
A few occasional stops from high speed won't be a problem at all for the OEM brakes.
Be sure to share your 700 HP build with us. Sounds killer.
Old May 23, 2013 | 11:09 PM
Modme's Avatar
Modme
Send some my way.
Ricio1991
Oct 17, 2018 11:24 PM
Kojack
Dec 15, 2015 07:03 PM
ck1109
Oct 20, 2015 03:34 PM
connoisseurr
Aug 16, 2015 04:26 PM
Ihtbealexxx
Aug 9, 2015 03:30 AM
