g37x coupe brakes
Old May 3, 2013 | 08:20 PM
Clutchr6's Avatar
Clutchr6
g37x coupe brakes
how change out the front brake pads. I couldnt get the locator pin out. What size alen key?
Old May 4, 2013 | 02:48 PM
OB G's Avatar
OB G
If you're changing out pads on the non s calipers shouldn't it just be a matter of undoing the lower bolt and sliding the caliper up? I think it's like a 14mm isn't it?
Old May 4, 2013 | 04:50 PM
vet350's Avatar
vet350
Angry G37x
I have a G37 two wheel drive car. I ordered rotors for a base model which I thiught I had. The rotors were 13 inch and didn't fit. When I called the teck line they said I had a G37x because my rotors were 12 inch. I this right! can I upgrade to 13inch? If I do will they fit my 17 inch wheels?
Old May 4, 2013 | 05:04 PM
Modme's Avatar
Modme
As far as I know, there are only 2 types of brakes on the G37:
Sport 4 piston front 2 piston rear:
Front: 13.98 × 1.260
Rear: 13.78 × 0.787
Non sport 2 piston front, 1 piston rear:
Front: 12.60 × 1.102
Rear: 12.13 × 0.630
Old May 4, 2013 | 07:25 PM
IMTASE's Avatar
IMTASE
The calipers you have are single piston and do use I believe a 7mm Allen. You cannot install larger rotors on your car because you will not be able to install the calipers.
G's
Nov 5, 2023 12:01 PM
G37xhibeet
Nov 15, 2016 09:29 AM
joeposter
Sep 8, 2015 04:36 PM
timc00k
Sep 5, 2015 05:12 PM
drewfinity
Aug 20, 2015 08:17 PM
