Rotor replacement DIY?
Boy oh boy, are you sure you want to try this yourself? Rotos/Brakes help stop the car and is way more serious than an intake bro and if done incorrectly can cause great bodily harm!!!
But if you really want to try it yourself here's a youtube DIY, good luck
DIY: Replacement of front brake pads and
rotors - 2008 Infiniti G37 - YouTube
I don't think brake jobs are a big deal and have done a few of them. Just make sure you bed the pads in correctly and make everything nice and snug. Better yet, if you can find the torque specs and have a torque wrench, that'll ensure that you get everything bolted up correctly. It is very DIYable and you shouldn't be afraid. Just make sure you have everything you need before you get started and take your time. It shouldn't be more than an afternoon's worth of work. Replacing the brake fluid and bleeding the lines are also a good idea if you haven't done them yet.
With mention of the intake...I feel like I'm missing something here...
Thanks! I have done brakes (pads, rotors and calipers) before......just wanted a step by step for the G due to un foreseen differences in set up and so I can get all the tools ready before I do it. Thanks for the link!
Just make sure you follow the torque specs on the caliper bolts. I think they are around 90 foot lbs. for the sport version. Everything else is pretty easy and straight forward. Always do one side at a time and make sure you bleed the whole brake system along with the change. Good luck and have fun.
Al
Al
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
photocat
Sep 3, 2015 01:46 PM
