Rear Sway Bar Upgrade
Old May 3, 2016 | 11:18 AM
  #106
jason05gt's Avatar
jason05gt
I installed a 370Z RSB on my X and it is the best bang for buck mod I've done in a long time. I paid $50 off of ebay shipped and installed it myself with a buddy. The car is much more responsive!
Old May 4, 2016 | 06:56 PM
  #107
IracknBack's Avatar
IracknBack
I've noticed a HUGE amount of oversteer on my car since installing the Stillen F/R sways. I also added SPC camber arms and lowered on Tein Basis coils at the same time so I can't attribute it to any one thing but I don't trust my car anymore to not kick the *** end out around a corner. feels better in most aspects but still uneasy about it overall.
Old May 5, 2016 | 01:53 AM
  #108
dragion's Avatar
dragion
What setting are the sways set at?
Try setting the front sway softer and see if that helps.
You might need to experiment a bit on both to get where you feel it handles the best.
Old May 5, 2016 | 10:03 AM
  #109
IracknBack's Avatar
IracknBack
I'd have to check, I had them installed by a shop when they did my camber arms since it was all right there. Thanks for the tip though.
Old May 5, 2016 | 11:30 AM
  #110
slartibartfast's Avatar
slartibartfast
Stiffer in the front to combat oversteer, not softer. Or, softer in the rear.
Old May 5, 2016 | 01:29 PM
  #111
iCrap's Avatar
iCrap
^ yep.
If your car oversteers too easily stiffen up the front or soften the rear.
Old May 5, 2016 | 05:50 PM
  #112
dragion's Avatar
dragion
Originally Posted by iCrap
^ yep.
My bad...I meant the other way around.
Thanks!
Old May 5, 2016 | 06:02 PM
  #113
Rr1982's Avatar
Rr1982
Is the awd Sedan front sway bar bigger than a sport sedan's?
Old May 5, 2016 | 11:53 PM
  #114
dragion's Avatar
dragion
Yes.
Ok...here it goes (dirty minds will be whirling now!)
The G37x(S) has the thicker and stiffer bar in front than any other G37...but has the thinnest in the rear.
By upgrading the rear sway to any of the RWD G37's sway will give you the best OEM combination.
This was the choice I made when I had my G37xS.
Old May 6, 2016 | 12:59 AM
  #115
Rr1982's Avatar
Rr1982
Originally Posted by dragion
Yes.
Superb! Thanks
Old May 6, 2016 | 02:33 AM
  #116
dragion's Avatar
dragion
Superb! Thanks
Welcome!
Old May 6, 2016 | 07:18 AM
  #117
slartibartfast
Best summer OEM combo. The AWD models are aimed at drivers who want extra confidence in inclement weather where softer is better. The smaller rear bar helps insure the car understeers and goes off the road nose first when traction is poor.
My one Autocross win in my CSP Sentra SE-R was during a deluge. The normal winning cars were set up for dry weather and their stiffer springs and shocks prevented them from hooking up. My almost-stock suspension allowed the tires to maintain traction, even when blasting through a huge puddle at the exit of the "fast" 180º turn.
I crewed for a friend getting his SCCA racing license in another Sentra SE-R. The final school session was at Texas World Speedway on a cold and wet February day. The decision was made to unhook both sway bars to make roll transition slow. We even went so far as to put eight-year old OEM tires on the car. My friend was slicing and dicing through the field like he was a god...only because almost all the other drivers went stupid and ran the course on race tires. He was amazed at how well the old, skinny tires hung on. 110 mph through small rivers running down the banking before braking for turn 1. Like Joe Piscopo in Johnny Dangerously my buddy thought about that once...ONCE.
The message here is that while you're making the car better for fair weather conditions, when the going gets ugly, you've reduced the usabilty of your car. Be sure to consider that when performing mods.
Old May 6, 2016 | 09:46 AM
  #118
dragion's Avatar
dragion
What you say is true for the track, but for everyday driving it should be fine.
Infiniti designed the AWD with the smaller rear sway to accommodate better handling for those who buy the vehicle looking for the "safer" ride during those types of conditions.
I reside in New England and we get our fair share of Winter weather...sometimes too much, so I know about the need for better traction during that time.
The rear sway upgrade is a mod which will be beneficial to the driving performance and not hinder the handling in a negative way...either in dry or wet/snow weather...this based on the OEM rear sway upgrade for the G37x(S).
Stiffening the rear sway too much with an aftermarket sway will probably steer toward more oversteer and can be dangerous.
This is based on my own personal experience with this mod.
Old May 6, 2016 | 05:55 PM
  #119
slartibartfast
Thanks for responding. While my experience does illustrate the issue, and applies just as much to the street as the track, I don't have direct experience with the X in the Salt Belt.
Old May 6, 2016 | 07:34 PM
  #120
dragion's Avatar
dragion
Your welcome.
I do agree with you 100% and anyone who plans to mod should research and make logical decisions on how these mods will effect the overall performance/handling/safety of the vehicle before doing so.
Just be thankful that you are in Texas and don't have to deal with our climate during the Winter months!
